MUM Europe 2020
Equis
Forum Veteran
Forum Veteran
OSPF Network Type
Fri Sep 21, 2007 11:03 am
Hello
For ether and wireless what should I use for OSPF Network Type?
Point to Point, Broadcast, NBMA etc..
janisk
Re: OSPF Network Type
Fri Sep 21, 2007 12:40 pm
most usually you can set broadcast, that is default value
macgaiver
Fri Sep 21, 2007 1:39 pm
So if you don't have any problems with the performance nor you have specific requirements use broadcast.
If you have large OSPF broadcast network, and you have many IR (Inner Routers) maybe it is good idea to reduce amount of OSPF peers - then you can set network type to NBMA and then specify only necessary neighbors manually in the NBMA Neighbor menu.
Point-to-point network type will reduce amount of the traffic on the link if you have only 2 directly connected hosts on this network.
ptmp - never found use for this
Users browsing this forum: AdiTane, alibloke, dioeyandika, eworm, Google [Bot], gswcomputer, MSN [Bot], OlofL, rioven and 130 guests
