BilboBel
WinBox error: Missing RouterOS WinBox plugins error
Tue Jan 18, 2005 3:47 pm
My winbox can't connect anywhere. Not even with the official demo. After a long forum search the closest match to my case is the message below. However I couldn't find any answer to this one. Has anyone solved it out?
> Hi guys,
> I've been using the 2.7 version of the RouterOS and Winbox for 2 months or
> so and I've been really pleased with it but the strangest thing happened
> today. I decided to reboot my computer and winbox would not connect to
the
> router. The program just hangs at "connecting to 10.1.1.1 (port 80)" and
> nothing happens.
> I didn't change anything at the router (no new rules etc). I've read the
> achieves and deleted the /documents and setting/user/application
> data/mikrotik folder. Downloaded the new binary from the router and run
it
> without any luck.
> I even searched my hd for virii and adware but nothing happens.
> Has anyone had this type of a problem before ?
> Oh BTW, I've tried it from another computer on the LAN and I am able to
> connect to the router. So, it's only my computer.
> Any ideas ?
normis
Tue Jan 18, 2005 4:45 pm
try re-downloading winbox from the router.
in the winbox loader, try clearing the cache
try deleting it's files in :
C:\Documents and Settings\Administrator\Application Data\Mikrotik
BilboBel
Tue Jan 18, 2005 5:23 pm
I ' ve done all of them but with no result :(
It is not a connectivity problem either since I can login via ssh at the mikrotik router.
Any other ideas?
yeruult
Sat Jan 29, 2005 7:28 am
Is there any firewall chain working? Like hotspot. You must check firewall settings and nat.
YazzY
Mon Jan 31, 2005 1:50 pm
This message appears when you run your winbox on port different from 80 or is disabled.
Check /ip services print
See if everything is okay
savage
Mon Jan 31, 2005 7:32 pm
Just FYI... If the request is going through a improperly configured proxy, the proxy will deny winbox from connecting to the router.
Regards,
Chris
ajmal
Re: WinBox error: Missing RouterOS WinBox plugins error
Mon Jan 31, 2005 8:49 pm
check services using /ip services print
and also check your firewall rule,is your source ip is excluded or not
ehammond
Tue Feb 08, 2005 11:47 pm
Is it possible to change winbox to different port than 80?
cmit
Wed Feb 09, 2005 6:53 am
Of course - under "/ip service"...
Best regards,
Christian Meis
ehammond
Wed Feb 09, 2005 1:47 pm
Duh! Thanks cmit
YazzY
Wed Feb 09, 2005 8:00 pm
Feels good to be quoted 3 times, even though when that's what it takes to make someone understand a thing :)
Users browsing this forum: dioeyandika and 49 guests
