MUM Europe 2020
surfnet
PCI-E ethernet ports
Fri Sep 28, 2007 12:30 am
I have a new ASUS P5M2(P)-E series motherboard.
It has 4 Marvell 88E8056 Giga PCI-E LAN Controllers that comply with PCI Express 1.0a Specs
The ports show up in 3rc5 and the lights light up to show a link. My laptop shows a link. Bu MK says no-link.
I tried hard setting the port speed,and each time I change something, I get the same result. The Laptop sees the connection but cant communicate via MAC or IP. The MK never shows the link as up, but the lights o the board light up.
any ideas? I would send a sup output file, but I cant get anything off the board.
believewireless
Re: PCI-E ethernet ports
Fri Sep 28, 2007 1:49 am
It's probably an IRQ conflict.
surfnet
Fri Sep 28, 2007 11:06 pm
so I am still struggling with this.
If I disable all the onboard ethernet ports, and put in a RB44 I get the same problem. they show but never show a connection.. even though the lights on the RB44 and on the switch light up.
If I simply take out the 3.0rc5 DOM and put in a 2.46 DOM, the unit boots up and all the RB44 ethernet ports work.
If this was an IRQ problem, wouldnt the problem exist in both versions?
surfnet
Fri Sep 28, 2007 11:08 pm
here is the IRQ list when running on 2.46
IRQ OWNER
1 keyboard
2 APIC
6 ether1
8 [rtc]
10 ether2
10 ether4
11 ether3
14 IDE 1
Great Man
Sat Sep 29, 2007 7:50 pm
Upgrade your BIOS (maybe it is not necessary) and disable (or enable? i am not sure now :)) option Power, ACPI APIC support. It will work.
surfnet
Sat Sep 29, 2007 9:10 pm
I have disabled everything I can in the BIOS, com ports, parallel ports, usb, power support, floppy
The weird thing is that is works in 2.9.46 and does not in 3.0rc5.
I will see if there is a BIOS upgrade available.
Great Man
Sat Sep 29, 2007 9:50 pm
After BIOS update try to Enable/Disable just this option - ACPI APIC support.
titius
Sun Sep 30, 2007 4:52 pm
have you checked the cable, is it crossover ??
surfnet
Thu Oct 04, 2007 10:54 pm
so the problem was ACPI APIC support.
It needed to be enabled, but I had it disabled
Ken
Users browsing this forum: Jerboy, McSee and 133 guests
