titius
order of mangle rules ?
Sun Sep 30, 2007 10:49 am
Hi
Which is the right order of mangle rules.
Specifically for conn mark and packet mark.
Do I have to place ALL Connection Mark first, and then Packet Mark.
Or I have to place it like, one Connection Markthen one Packet mark for that conection and so on . . .
Or it depend which chain Im using.
Forward, preroutin postrouting.
Chupaka
Re: order of mangle rules ?
Mon Oct 01, 2007 1:47 am
it does not matter
you can first mark all connections, then mark each connections' packets, or you can mark connections1, then it's packets, then connections2, then connections2's packets and so on. as you like
titius
Mon Oct 01, 2007 8:40 pm
Thanks for answer,
Whem Im in preroutin chain, marking all connections first and then their packets doesnt work, it works only in forward chain, or am I doing something wrong :)
Chupaka
Tue Oct 02, 2007 1:38 am
titius, I do marking in prerouting, all works fine. Post here the result of
ip firewall mangle print
titius
Tue Oct 02, 2007 11:04 pm
it works fine I was a little bit confused :( .
Users browsing this forum: MSN [Bot] and 116 guests
