MUM Europe 2020
elkolo23
squid vs mt
Mon Oct 01, 2007 1:07 am
Which do you prefer,, squid server or webproxy??
personally i have mt webproxy but i ave a friend which has squid machine and it seems to me it runs better..
would like your opinion Normis
Chupaka
Re: squid vs mt
Mon Oct 01, 2007 1:32 am
in MT, you have no advanced configuration of proxy, just simple proxying. if this is not enough - then setup one more linux machine with squid
Equis
Forum Veteran
Forum Veteran
Re: squid vs mt
Mon Oct 01, 2007 2:05 am
Horses fo Corses.
On a large network I use squid, but on small netwok with limited resorsed MT cache is good.
samsoft08
Long time Member
Long time Member
Re: squid vs mt
Mon Oct 01, 2007 6:21 am
beside we can do tuning for the squid what is the other advantages ? faster ? hit % better ?
Equis
Forum Veteran
Forum Veteran
Re: squid vs mt
Mon Oct 01, 2007 6:24 am
My favorite is you can see under the hood :-)
eg how much cpu/mrm its using etc.
fatonk
Re: squid vs mt
Mon Oct 01, 2007 6:55 pm
Regarding the squid vs mt it is faster, it supports wccp if you have cisco routers in the network, you can create a cache farm and it works very good.
Regards.
Faton
t3rm
Re: squid vs mt
Thu Oct 11, 2007 7:20 pm
Quite strange topic ..
:lol:
Mikrotik vs Squid.
From what i knew, Mikrotik build the proxy based on Squid also.
So you can only see the differences between both, only on the parameters.
Squid provide more and more advanced configurations, while Mikrotik.
It just simplify the complex configurations from Squid.
CMIIW
- Rio.Martin -
alex_rhys-hurn
Re: squid vs mt
Fri Oct 12, 2007 8:30 am
One of the reasons I like squid is that there are a lot of modules out there for it.
So I can add content filtering with Dans Guardian or even use it to handle Microsoft, Adobe, Symantec Updates.
All depends on the deployment......
normis
Re: squid vs mt
Fri Oct 12, 2007 3:24 pm
no, mikrotik proxy is NOT based on squid or anything else.
alex_rhys-hurn
Re: squid vs mt
Fri Oct 12, 2007 6:20 pm
Is there anyway of integrating thrid party moduls such as dansguardian with the new mikrotik web proxy?
I understand that all sorts of blocking and things can be done with it, but I would quite like to be able to filter traffic against some well known and possibly even custom black lists......
By the way the new mikrotik web proxy that I am using in 3.0 is as you advertise super fast, especially with my sata harddrive....
t3rm
Re: squid vs mt
Sat Oct 13, 2007 8:05 am
Normis: :lol: :lol: :lol:
This is what i got from one of my client running 2.9 Mikrotik Webproxy.
Did telnet to its proxy and got the result like this:
HTTP/1.0 400 Bad Request
Server: squid/2.5.STABLE11
Mime-Version: 1.0
Date: Sat, 13 Oct 2007 13:04:59 GMT
Content-Type: text/html
Content-Length: 1177
Expires: Sat, 13 Oct 2007 13:04:59 GMT
X-Squid-Error: ERR_INVALID_REQ 0
X-Cache: MISS from proxy
Proxy-Connection: close
:shock: :shock:
alex_rhys-hurn
Re: squid vs mt
Sat Oct 13, 2007 11:10 am
Mime-Version: 1.0
:shock: :shock:
Well, if you look properly in the packages list for Mikrotik Ros 2.9 you will see that there is proxy and web-proxy. In other words there are TWO web proxy versions.
One of them is the mikrotik web proxy and the other one is the original squid based one. It looks like you are running the squid based one.
In Mikrotik ROS ver 3 the old squid based proxy has been dropped all together in favour of the Mikrotik one.
And so Normis is right the Mikrotik one is not based on anything else. I guess they should know. They wrote it... :)
hulk-bd
Re: squid vs mt
Sat Oct 13, 2007 2:49 pm
Dudes,
The whole MT kernel is based on linux. So nothing to say...
:lol:
Don't worry, be happy :) .......
Chupaka
Re: squid vs mt
Sat Oct 13, 2007 2:55 pm
Dudes,
:lol:
proxy is NOT kernel. you should know that
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
hulk-bd
Re: squid vs mt
Sat Oct 13, 2007 3:07 pm
Hey Kid,
Did I said proxy is kernel? I said the main kernel based on linux and in linux the proxy is squid you can just tune it for better for your OS. The MT web proxy in 2.9 is based on squid and I know MT team is building their own proxy in version 3. But my point is everything here are based on linus kernel, but I think MT OS web proxys idea came from linux squid.
Never underestimate any body, ever.
Chupaka
Re: squid vs mt
Sat Oct 13, 2007 3:59 pm
Hey Kid,
Linux idea came from UNIX, but Linux do not based on UNIX, it is written from scratch. "The MT web proxy in 2.9 is based on squid" - no it does not. ROS 2.9 web proxy is squid, but MT proxy in ROS 2.9 (webproxy-test package) is not squid.
So, Sweety, "entities should not be multiplied beyond necessity" (c) Okkam
hulk-bd
Re: squid vs mt
Sat Oct 13, 2007 7:48 pm
OH Sorry!? I didn't know about you sir, Now I can see you are the boss here.!???? :shock:
Chuida mure kha.
Thanks n Peace
t3rm
Re: squid vs mt
Sat Oct 13, 2007 8:16 pm
Confirmed on MT 3.0RC6
I did activate the Web Proxy, and did test the proxy connection.
Dunno different from squid or not, but got the similar result like Squid, except for the name.
(MikrotikHttpProxy)
Well i guess, the version 3 is different from 2.9
So lets get back to topic. Anyone already test this head to head scenario ?
MT Webproxy vs Squid ?
alex_rhys-hurn
Re: squid vs mt
Sun Oct 14, 2007 2:06 pm
I have tested them head to head but not for performance, for features.
And like I said before I prefer squid for its modularity.
For speed reasons I think its a difficult test as MT is used in so many different ways by so many different people, on different hardware....
So the MT proxy on a router that has lots of mangle rules, and dynamic queues and so on which constitutes a real life scenario may be giving more processor cycles to those tasks that to proxy work.
A dedicated squid server is just that. dedicated.
Also we must consider the speed of the switching fabric between the router and the web proxy....
So, I like both of them, but I use them in different situations.
normis
Re: squid vs mt
Mon Oct 15, 2007 1:28 pm
Chupaka is right. We used squid in older versions, but the new RouterOS proxy is made entirely by us, it is based on nothing else. It is faster, and over time we will add more features.
samsoft08
Long time Member
Long time Member
Re: squid vs mt
Sun Oct 21, 2007 7:23 am
yes , good job , but the most important thing is to make your web-proxy working with V3Rx , couse I can run V3 for weeks without any single problem , BUT whenever i enabled web-proxy i have to expect system hang-up !!!!
i dont know am I the only one who is testing web-proxy with V3 ?????
normis
Re: squid vs mt
Mon Oct 22, 2007 9:04 am
we are using in in many networks, it has no issues. if you have problems, email support.
samsoft08
Long time Member
Long time Member
Re: squid vs mt
Sat Oct 27, 2007 1:11 am
its freezing again , after 5 hours !!!! nothing happened without web-proxy enabled !!!!
may be its becouse i'm running hotspot on a bridge ?? i'm running hotspot with bypass for all known clients .. and a adv page for the strangers (regular)..
Chupaka
Re: squid vs mt
Sat Oct 27, 2007 1:32 am
hmmm... I've updated my 2.9.27 to 3.0rc9... it hang in some hours... now its uptime is 5 hours... I do not use hotspot, only simple routing w/NAT and web-proxy... maybe just incident...
Chupaka
Re: squid vs mt
Sat Oct 27, 2007 4:09 pm
just logged in via WinBox... and MT hang in about 5 seconds =(
probably will downgrade to 2.9.48 =(
samsoft08
Long time Member
Long time Member
Re: squid vs mt
Sun Oct 28, 2007 1:39 am
with RC9 , no freezing for 15hour untill now !! with web-proxy enabled .....
larmaid
Re: squid vs mt
Thu Nov 08, 2007 5:30 am
so.....which version is the stable one...??? :)
i like it
Chupaka
Re: squid vs mt
Thu Nov 08, 2007 1:08 pm
RC9 is unstable in PPTP server
Users browsing this forum: almdandi, Bing [Bot], eworm, fedus, OceMx and 124 guests
