MUM Europe 2020
trottolino1970
passtrought
Wed Oct 03, 2007 5:28 pm
everyone says that passtrought is able or enable. so what i do?
Chupaka
Re: passtrought
Thu Oct 04, 2007 12:14 am
what do you mean?..
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
karo84
Re: passtrought
Thu Oct 04, 2007 1:07 am
when you enable passthrough it means that packet will continue to be marked or something else done by the next rules
example
/ip firewall mangle add
11  chain=prerouting src-address=191.203.26.196/31 dst-address=84.235.229.0/24 action=mark-packet new-packet-mark=123 passthrough=yes
12  chain=prerouting src-address=191.203.26.196/31 dst-address=186.235.229.0/24 action=mark-packet new-packet-mark=123 passthrough=no
13   chain=prerouting src-address=91.203.26.196/31 action=mark-packet new-packet-mark=124 passthrough=no
In 11 rule packet will continue its pass to the lowest rules it will be marked and stoped on the 12 rule if the destination matched to 84.235.229.0/24, if destination is not 84.235.229.0/24 network it will continue and will be marked and stoped at 13-th rule
With Regards
Karo Aznavuryan
trottolino1970
Re: passtrought
Thu Oct 04, 2007 10:44 am
example
With Regards
Karo Aznavuryan
so if i have passthrough=no in all my rules my packets are marked only for first rules or for all rules? for examplewhen i mark the connection the passthrough will be enable or no? then i mark the packet now the passthrough will be enable or no? If i have two adsl the passthrough will be enable in all mark packet or only in mark connection?
karo84
Re: passtrought
Thu Oct 04, 2007 1:37 pm
Look when u mark and disable the passthrough option packets that matched that rule (source, destination) will not apear in the lowest levels
If u have 2 adsl. you have to mark and disable passthough option to mark your traffic for all marking(Connection and Packet)
trottolino1970
Re: passtrought
Fri Oct 05, 2007 11:28 am
but in this mode the queue is stopped for all traffic
trottolino1970
Re: passtrought
Fri Oct 05, 2007 2:09 pm
ok if i make passtrought only to connection.mark and not passtrought to packet market , all ok for all
Users browsing this forum: No registered users and 100 guests
