MUM Europe 2020
diyu
RB133 with High Power MiniPCIs
Thu Oct 04, 2007 4:24 pm
Hello Guys,
Please share your review or comment while using RB133 with 3 High Power MiniPCI (let's say 3 pcs of R52H or 3pcs of XR2). And what about the specification of power supply we need ? to get the maximum performance.
Thank You
Viroslash
Re: RB133 with High Power MiniPCIs
Thu Oct 04, 2007 5:32 pm
U can use 48V 2A power supply
Foro MikroTik en Español
http://www.foromikrotik.com.ar
BrianHiggins
Long time Member
Long time Member
Fri Oct 05, 2007 6:38 am
Hello Guys,
Thank You
do yourself a favor... if you're trying to run multiple radio's, espicially high powered ones, use a board with a faster processor then a 100 series board. use a 532 or a 333. you need the CPU power if you're doing alot of wireless.
stephenpatrick
Forum Veteran
Forum Veteran
Fri Oct 05, 2007 1:16 pm
.... Bzzzzzt.... there goes your board, up in smoke ....
Seriously, don't apply 48V to that board !
CableFree - Wireless Excellence - Microwave, E-band Radios, Free Space Optics, High performance Radios & Routers
http://www.cablefree.net
rafaelcamplone
Tue Nov 06, 2007 11:31 pm
Dont use 48v on routerboard 133, only the old boards are capable to work with 48v, your routerboard works fine with 24v 1-2 amp
http://www.elife.com.ar/rafael
Rafael Camplone
slipstream1
Wed Nov 07, 2007 2:28 pm
The Rb133 has overvoltage protection built in and will not fry when 48vdc POE is applied. It will just not power up.
As for the original question, I have several Rb133 with 3 SR9 running. They perform just fine. I am in the process of replacing the SR9's with XR9's and they are performing fine also. As others have stated, the processor is where the bottleneck occurs. Since 900 mhz is a last resort for my network, I do not have that many customers running on 900 mhz. So, the RB133 works for me.
Users browsing this forum: MSN [Bot] and 68 guests
