MUM Europe 2020
kvan64
Modem settings for using PPPoE set on MT router
Sat Oct 06, 2007 1:28 am
Hi, I was told that the modem should be set to bridge mode when using PPPoE-client set on MT to dial out. It just that there are many different type of bridge modes on my modems. Which one is correct settings? What do you use in your?
Ta
Chupaka
Re: Modem settings for using PPPoE set on MT router
Sat Oct 06, 2007 3:18 am
which ones? i thought bridge mode is just bridge and nothing else... which modes? :)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
yudhi
Mon Oct 08, 2007 4:01 am
Ta
I used routing mode from my ADSL modem, so the modem will do the PPPoE authentication to the provider while on the MT just set the modem IP as gateway.
But for bridge mode, MT should handle the PPPoE authentication.
CMIIW
kvan64
Mon Oct 08, 2007 3:12 pm
Thanks for your replies guys. I have tried both DHCP-client and PPPoE-client for IP configurations and found that PPPoE-client set on MT gives me less Internet dropouts comparing to DHCP-client (modem hands out IP and leases internet connection). It just that my new ADSL2+ has four (4) different bridge settings in it! Doesn't matter, I just try them all and figure it out :)
Thanks again.
Users browsing this forum: Bing [Bot] and 102 guests
