MUM Europe 2020
hytanium
RB 133c - Will it ever work with v3x
Sat Oct 06, 2007 6:58 am
Are there plans to make this version work with v3 ROS? I have tried running the version 3 with very little success. Soon as I pop in an SR9 or 5 the unit dies...... I've also tried with very few packages.
Anyone?
Equis
Forum Veteran
Forum Veteran
Re: RB 133c - Will it ever work with v3x
Sat Oct 06, 2007 9:02 am
I use ROS3 rc6 with rb133/c and its perfect for me.
Radios are r52's and also a XR2
andreacoppini
Trainer
Trainer
Sat Oct 06, 2007 1:11 pm
same here.
i have RB133s running ROS v3rc5, one of them with a CM9 and an SR2
- No strings attached -
<< Please give good Karma if this post helped you. Press the + button above the Location entry
hytanium
Sat Oct 06, 2007 2:39 pm
What packages do you have enabled??
andreacoppini
Trainer
Trainer
Sat Oct 06, 2007 2:48 pm
The default ones:
advanced-tools
dhcp
ntp
ppp
routerboard
routing
security
system
wireless
(ipv6 and hotspot installed but disabled)
ghmorris
Sat Oct 06, 2007 3:56 pm
We have 133, 133c and 112 running ROS 3.0rc6. All have SR9s in them.
Definitely seeing a memory leak. About 1Mbyte decrease in available RAM in 12 hours so far.
Causes more problems to the 112 and 133c obviously.
  #   NAME                      VERSION
 0   system                    3.0rc6
 1   security                  3.0rc6
 2   routeros-rb500            3.0rc6
 3   routerboard               3.0rc6
 4   routing                   3.0rc6
 5   wireless                  3.0rc6
 6 X ipv6                      3.0rc6
 7   advanced-tools            3.0rc6
George
hytanium
Mon Oct 08, 2007 7:34 am
The default ones:
advanced-tools
dhcp
ntp
ppp
routerboard
routing
security
system
wireless
I will try the package again with the SR9. If it does not work I will try the SR5 ...
jorj
Tue Oct 09, 2007 11:08 am
Could only make it work stable on 133. 133c and 112 dies after hours or immediatly after few clients link to the ap.
Also if you try to put a btest trough it, to another router, it resets itself. ( verified multiple times with 133c and r52/r52h/tonze/alfa )
All of them, same problem. Same wireless chipset.
133 is stable as far as I can see. The only 1xx stable, from what i have.
ianek
Tue Oct 09, 2007 9:57 pm
It is leaking on this platforms ( 532, 133, 112 etc.)and eating CPU , but seems noone care, as it works on x86 intel platforms.
I hope they will fix it soon, im curious it is working for you on 133. On old wrap - 686 geode CPU i have no problem with RC6.
Jan
jwcn
Wed Oct 10, 2007 4:51 am
It's working fine for me on several 133's
tgrand
Long time Member
Long time Member
Wed Oct 10, 2007 2:40 pm
Remove the packages you are not using to conserve memory.
Also Try disabling the NTP package, as it can create problems.
Users browsing this forum: befluid, dz1mm3rm4n, McSee, svmk and 86 guests
