MUM Europe 2020
szchris
You must upgrade router to 2.9.46
Tue Oct 16, 2007 4:40 pm
serjegs
I will going to upgrade to 2.9.46.
by the way can you kindly tell me
what's going on for the protocol = 0 in the [ip firewall connections]
tks very much
Chris
NNNN
Chupaka
Re: You must upgrade router to 2.9.46
Tue Oct 16, 2007 11:42 pm
I have ROS 2.9.43 and faced this phenomenon, protocol = 0. do upgrading to 2.9.46 fixes this issue?
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
changeip
Wed Oct 17, 2007 12:05 am
protocol = 0 is usually ICMP or other I believe... non tcp/ip stuff.
Colo and Wholesale Bandwidth Available! Sales at SanDiegoBroadband dot com
Chupaka
Wed Oct 17, 2007 12:23 am
ICMP is 1
zero protocol is out of standarts =) but occasionally some connections revert to zero protocol =(
maximan
Trainer
Trainer
Wed Oct 17, 2007 12:58 am
udp port 0 = Ares
M.
MKE Solutions > Professional Support IT (Spanish / English)
FastNetMon / FNM Manager: DDoS Detection Tools.
szchris
Wed Oct 17, 2007 12:21 pm
Chupaka
Why don't you upgrade to 2.9.46
I had try that it accept protocol = 0 input in the firewall filter
maximan
What u mean the upd port 0 = ares
Can you tell me
anybody body to tell us why the connection tracking will get record with protocol = 0
Tks a lot
Chris
NNNN
Chupaka
Thu Oct 18, 2007 12:18 am
that's easy: I do not want to interrupt working server ;)
Ozelo
Fri Oct 19, 2007 3:11 pm
Can you guys sleep with the sound of this...?
MTCRE - 1104RE006
MTCINE - 1104INE001
normis
Tue Oct 23, 2007 11:02 am
well there is nothing special mentioned. most of the stuff is corrected in v3 and the winbox finding can be solved by using a tunnel. of course we will improve these things :)
Ozelo
Tue Oct 23, 2007 1:46 pm
*cheers* :)
MTCRE - 1104RE006
MTCINE - 1104INE001
janisk
Tue Oct 23, 2007 3:21 pm
if you do not experience any problems with current configuration and version - then use the router, if you encounter problems, first thing to do is upgrade to newest version available and see if problem persist, if it does, then report to support.
so, when everything works - why upgrade.
Users browsing this forum: No registered users and 74 guests
