MUM Europe 2020
kvan64
Downgrade command not working
Sat Oct 20, 2007 2:34 am
It no longer work through command lines </system package downgrade>. There is still an option in webbox but it wouldn't work either.
Gerard
Trainer
Trainer
Re: RC7 Downgrade command nolonger work/available
Sat Oct 20, 2007 3:31 am
kvam64,
downgrade is working fine.. Just tested a rb333, upgraded to rc7, downgraded to rc6, then back to rc7 again.
Upload .npk files for previous version you would like to downgrade to then run /system package downgrade or in winbox you can click system -> packages then click on the downgrade button.
-Gerard
kvan64
Downgrade command
Sat Oct 20, 2007 4:21 am
I tried it again but just doesn't work for me. System is not downgraded after restarting (PC).
skillful
Trainer
Trainer
Re: Downgrade command not working
Sat Oct 20, 2007 12:10 pm
The packages may be corrupt. Delete all uploaded packages in /files and upload them afresh. Then issue the downgrade command
Gerard
Trainer
Trainer
Sat Oct 20, 2007 4:10 pm
Also make sure that you didn't upload the files into one of the hotspot directories/folders. The files will need to be in the root. Also check the log it should tell you why the downgrade didn't work.
-Gerard
kameelperdza
Tue Jan 27, 2009 10:08 am
can the wrong or currupted version damage the routerboard
Give me some karma
janisk
Tue Jan 27, 2009 4:13 pm
you always can try to reinstall routeboard using netinstall tool
edit:
i do not know any such cases when bad version of routeros have damaged routerboard hardware and in testing pre-release version i always have used netinstall if something went wrong.
Users browsing this forum: mmastrac, MSN [Bot] and 148 guests
