brianlewis
EoIP over unsecure tunnel - how?
Wed Jan 26, 2005 5:43 pm
http://www.mikrotik.com/docs/ros/2.8/in ... ip.content
Documents how to setup EoIP over a secure PPP connection. I like to perform this same function without PPP, do I just start setup similiar to STEP#2 and go forward from there, ignoring Step #1?
Or do I need to configure something else for Step1?
YazzY
Wed Jan 26, 2005 10:42 pm
You can create EoIP tunnels over layer 3 as long as both sides can see eachother.
In other words, PPP is used for a VPN solution for EoIP, but you can as well run it over internet between two hosts which can "see" eachother.
wildbill442
Fri Jan 28, 2005 12:51 am
What's the advantages of using EoIP instead of a traditional bridge?
cmit
Fri Jan 28, 2005 8:21 am
At least as far as you want to do this over a wireless link, you simply can't just bridge your wireless and ethernet interfaces. But you could create an EoIP tunnel and then bridge the ethernet and EoIP interfaces...
Best regards,
Christian Meis
YazzY
Fri Jan 28, 2005 10:37 am
You can bridge your wlan interfaces with ethernet interfaces on the same unit just fine.
EoIP is to bridge two distant networks over ethernet, not just two nics on the same box.
edzix
Fri Jan 28, 2005 11:00 am
Note! ...wlan if it's in AP or bridge mode
Edgars
Users browsing this forum: Bing [Bot] and 77 guests
