bejcd
IPSec with dynamic peer ...
Wed Oct 24, 2007 11:20 pm
Does anybody have experience how to fill out IPSec -> Peers -> Address section with Dynamc IP address ?
If a remote IPSec firewall dynamically changes IP is it possible to somehow manage that from Mikrotik router locally ?
Appreciate all your suggestions.
Thank you,
D.
bejcd
Re: IPSec with dynamic peer ...
Thu Nov 08, 2007 9:26 pm
Hello again,
When I meant a 'dynamic' address that is in a form of A-record (or DNS name ... name.domain.com - not a static IP address).
Thank you,
D.
andrewluck
Forum Veteran
Forum Veteran
Thu Nov 08, 2007 11:18 pm
You specify the peer address as 0.0.0.0/0 and set the option 'Generate policy' in the peer setup. This will allow connections from different IP addresses. At least one end must have a fixed address.
Regards
Andrew
bejcd
Tue Nov 20, 2007 6:58 pm
Thanks Andrew for your help,
I have already figured it out by myself ... pretty obvious but sometimes it takes some time.
Again, deeply appreciate your help.
D.
lgraveman
Tue Feb 05, 2008 6:30 pm
Hello, Newbie, could you share your case for our reference? We also need help.
graveman
D.
yacsap
Mon Sep 03, 2018 11:18 am
Regards
Andrew
Hi Andrew,
In order to achieve a dynamic ipsec peer, is it better to setup Generate policy as port strict or port override? What's the difference?
Cheers! 🥂
[ IMikroTik ] >
sindy
Mon Sep 03, 2018 11:32 am
10 years ago this choice didn't exist :-) The port-override choice only makes sense when the peer sends incorrect traffic selectors in the proposal; with correct peer implementation, port-strict works fine.
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
Users browsing this forum: Bing [Bot], Kindis, sindy and 68 guests
