kolorasta
strange ips in connections
Fri Oct 26, 2007 4:36 pm
in firewall/connections I see this
you may say it's normal, but my local network is 172.16.0.0/21
why connections for the ip 192.168.0.20 (which is supposed to be reserved for private ips) are shown???
Am I misunderstanding something?
krigevr
Re: strange ips in connections
Fri Oct 26, 2007 7:08 pm
I'm gonna assume there's a NAT gateway in there somewhere with an address of 192.168.0.20.
The addresses listed there looks to me like all connection originating from host or network behind 192.168.0.20.
... or not. :-)
-K
kolorasta
Fri Oct 26, 2007 7:17 pm
my MT is natting a 172.16.0.0/21 network.
you can't find a 192.168.*.* in my whole config
krigevr
Fri Oct 26, 2007 7:21 pm
*eek*
OK
That's uber ood.
Not even a router somewhere within your network?
What does a Traceroute say about that address?
kolorasta
Fri Oct 26, 2007 8:04 pm
when i do a traceroute it tries to go through my wan interface and then TIMEOUT
i didn't mention that there are lot of routers in my network... there can be a 192.168.0.20 pc... but it is natted by the client router. i think there is no reason to appear in the connection list of my MT.
UniKyrn
Fri Oct 26, 2007 8:10 pm
Is your NAT rule written so that it only NAT's your 172.16 source address, or is it NAT'ing anything on your internal interface that goes out your external interface? That 192.168 address is obviously being NAT'd or it wouldn't be talking to anybody. That's a pretty odd source and destination port combination collection as well.
I'm thinking you've got a NAT rule that is somehow written to accept any input address and somebody is running a P2P client using the 192.168 source address.
What's the timeout on established sessions? The difference between that and the 3:30 those sessions have left to timeout will tell you when the computer was last active.
You might put in a firewall rule to deliberately drop 192.168.0.0/16 also, or better yet, drop anything that isn't 172.16.0.0/21 on your internal port :)
kolorasta
Fri Oct 26, 2007 10:42 pm
this is an EXPORT from my nat config
nothing strange... all done like it's said in the manual
# oct/26/2007 16:40:06 by RouterOS 2.9.48
# software id = ****
/ ip firewall nat
add chain=srcnat action=masquerade out-interface=WAN src-address=172.16.0.0/21 \
    comment="masquerade" disabled=no
add chain=srcnat action=accept dst-address=172.16.0.1 dst-port=80 protocol=tcp \
    comment="don't cache connection to router" disabled=no
add chain=dstnat action=redirect to-ports=3128 in-interface=LANbridge \
    src-address=172.16.0.0/21 dst-port=80 protocol=tcp comment="web-proxy \
    redirect" disabled=no
Users browsing this forum: MSN [Bot] and 103 guests
