savage
routes?!?!
Tue Nov 13, 2007 10:34 am
can someone explain this please? Running RC10, I need this fixed ASAP... The router was fine, over a period of time (less than 24hrs) it started doing this.. Dual Core Intel system with 2GB of RAM, system resources is hardly a issue...
[cknipe@CTN-CORE01] > /ip route print
 #      DST-ADDRESS        PREF-SRC        G GATEWAY                DIS
[cknipe@CTN-CORE01] > /ip address print
 #   ADDRESS            NETWORK         BROADCAST       INTERFACE
 0   172.19.44.253/24   172.19.44.0     172.19.44.255   Internal
 1   196.xx.xx.253/28    196.xx.xx.240  196.xx.xx.255  External
 2   196.xx.xx.133/29  196.xx.xx.128  196.xx.xx.135  External
 3   196.xx.xx.173/29  196.xx.xx.168 196.xx.xx.175 External
 4   172.19.44.254/32   172.19.44.254   172.19.44.254   VRRP - Internal
 5   196.xx.xx.254/32  196.xx.xx.254  196.xx.xx.254  VRRP - DigiNET MPLS
 6   172.19.45.29/32    172.19.45.29    172.19.45.29    VLAN10 - High Priority
 7   172.19.45.30/32    172.19.45.30    172.19.45.30    VRRP - VLAN10
Where is my routing table? Why does it not even display routes for connected networks? I have no routing table in winbox or console, adding a route manually via console or winbox does nothing. Rebooting the router does NOT fix the issue
Regards,
Chris
jacoblydon
Re: routes?!?!
Wed Dec 05, 2007 5:37 am
I have seen this happen to me. What version O.S do you run. You may hate to hear this but, this sometimes means to me that router board is (flakey), is it new? Will traffic still route?
savage
Re: routes?!?!
Wed Dec 05, 2007 6:29 am
was a problem between a temporary level 1 license that was installed and the routing package in RC10. This was apparently corrected in RC11
Regards,
Chris
BrianHiggins
Long time Member
Long time Member
Re: routes?!?!
Wed Dec 05, 2007 8:57 am
i've seen this happen in v2.9 before... hasn't happened to any of our v3 test units though.
Users browsing this forum: Google [Bot], Rikjaard, tovi, Trigger and 76 guests
