MUM Europe 2020
ashish
Long time Member
Long time Member
Confused with Configuration
Wed Nov 21, 2007 7:13 am
I am Little confused with following senario.
I have RB133C-and want ti use for HotSpot
Incoming Internet IP for ether1 is ->172.16.48.48/23, But to use internet on this IP i need to assign Proxy address. Where to assign Proxy address.
My Out going IP for hotspot is 192.168.0.1/24.
- AP - ASHISH PATEL - 757 309 0236 -
jacoblydon
Re: Confused with Configuration
Wed Dec 05, 2007 5:25 am
I am quite sure that rb133c does not have license capabilities to run as AP. Rb133c is designed for client scenario . rb133 does support AP. It can't handle a lot of load, and lacks memory resources. It may work fine with a handful of clients though. Does this help you?
sergejs
Wed Dec 05, 2007 9:52 am
HotSpot does not sound like solution for CPE.
RB133c is CPE board.
There is option in 'ip hotspot profile',,
http-proxy (IP address; default: 0.0.0.0) - the address of the proxy server the HotSpot service will use as a proxy server for all those requests intercepted by Universal Proxy system and not defined in the /ip proxy direct list. If not specified, the address defined in parent-proxy parameter of /ip proxy. If that is absent too, the request will be resolved by the local proxy
Users browsing this forum: fusa, Google [Bot], MSN [Bot] and 52 guests
