HellMind
Port Forwarding isn't work
Sun Dec 02, 2007 2:24 am
My network is working.
I am able to use the Internet "Adsl 5Mbps" from the boxes on 192.168.1.0/24.
Port forwarding isn't work, do I need something special?, I only use the port forwarding rule on the RouterOs with the "Adsl 5Mbps" internet.
It works from the boxes on that place (192.168.4.0/24 , 192.168.5.0/24)
But isn't work for the remote ones.
I can ping everywhere from everywhere,
The wifi link is a bridge wds.
jp
Long time Member
Long time Member
Re: Port Forwarding isn't work
Sun Dec 02, 2007 2:14 pm
show us the nat rule. Instead of srcnatting the IP block you might have to do everything outgoing.
/ ip firewall nat
add chain=srcnat action=masquerade out-interface=ether1 comment="" disabled=no
or something like it.
Users browsing this forum: No registered users and 80 guests
