gustkiller
Queue Tree , QoS and simple queues for pppoe not working..
Tue Dec 04, 2007 6:49 pm
I allways used hotspot for my customers but,I started to use pppoe with some costumers.
The problem:
I have a Queue tree for QoS and max limite per mangled packet marks. ex: HTTP highers priority than FTP for exemple..
One master Queue for Download = Attached to lan interface with subqueues to distribute the traffic for each protocol/mangled packet.
Another master Queue for Upload = Attached to wan interface with subqueues to distribuite the traffic and priotity for each protocol / mangled packet.
I noticed that the traffic generated by the pppoe connected clients doesnt pass trough the queue tree. ex: a costumer downloading something from http at 2mbits/s , the traffic doesnt show up in queue tree master queue and the child queue.
Master queue = showing 8mbits but the real traffic from all clients , the hotspotted and pppoe is 10mbits.
So after re-reading the Mikrotik manual i set the Father queue for download as global-in and the upload father queue i set the parent as global-out.
i forgot to say that i use a radius server that sends to mikrotik the simple queue for each costumer with the speeds for each one.
Than i noticed that when i set the queue tree parents as global-in and global-out the simple queue stoped to work and started to mark 0 traffic.
I would like to know if there's any way to set the queue tree to work with pppoe costumers, without messup with the simple queues.
Thanks.
sergejs
Re: Queue Tree , QoS and simple queues for pppoe not working..
Wed Dec 05, 2007 8:42 am
You have to avoid configuration, when the same traffic is limited in 'queue simple' and 'queue tree'.
Use 'queue simple' entries only, if you have dynamic PPP queues created.
Add static entries to 'queue simple', when you need advanced QoS scenarios (packet-mark is available there too).
Make sure that static queues for specific services are placed before dynamic queues (that match all traffic), rule order is important.
gustkiller
Wed Dec 05, 2007 1:35 pm
That's exactly what i wanted.
Thanks!
spokke
Mon Jun 11, 2012 1:56 pm
hi ... i know that the post is old, but i'm in same situation...
how can i set global-in and global-out in simple queues (don't show on parent or interface)..
must i apply on internet interface and on pppoe interface ?
thank you very much
spokke
Tue Jun 12, 2012 4:02 pm
this is my situation but seem not working :(
packet marking is working because packet counters increase well ...
thank you
marioclep
Trainer
Trainer
Tue Jun 12, 2012 6:00 pm
each simple queue is composed by one global-in + one global-out + one global-total... so if you user global-in and global-out interfaces in HTB, then simple queues will not work. Try using physical interfaces (wan / lan)
Ing. Mario D. Clep
CTO - MKE Solutions
MikroTik Certified Trainer
spokke
Tue Jun 12, 2012 6:12 pm
thank you for your reply ... i've already used phisical interface on interface tab ... (do you mean this ? ) :)
thank you again
Users browsing this forum: markos222, mbovenka, Phorta, xvo, Zacharias and 89 guests
