radocicala
UDP or TCP ports 135-139?
Sat Dec 29, 2007 1:15 am
I use firewall rule:
add chain=virus protocol=udp dst-port=135-139 action=drop comment="Drop Messenger Worm"
and this rule blocks these ports almost of every my client. I am affraid of not to block any service needed by my clients. What are that ports needed for? Is better to block them or allow them. Or block almost every client means that almost everybody is infected by messenger worm?
bushy
Re: UDP or TCP ports 135-139?
Sat Dec 29, 2007 1:48 am
Usually used for NetBIOS stuff , it is better to block them .
jp
Long time Member
Long time Member
Sat Dec 29, 2007 4:19 am
Yes, if they want to do this windows networking stuff over the Internet, it should be done with an encrypted VPN. If you see those ports, you can safely block it.
radocicala
Sat Dec 29, 2007 8:36 pm
Thanks for your help.
Users browsing this forum: achenor, anav, Baidu [Spider], Google [Bot], Lizzardd, ysha and 64 guests
