IMRAN KHOKHAR
Load-Balance with dynamic gatway setings
Tue Jan 08, 2008 10:27 pm
how can i use 2 or more interface without static IPs or gatwayes? i have only dynamic IPs and gatwayes with WAN?
how can posibale to load-balance with (dhcp) dynamic WAN setings?
like; WAN-1 (with DHCP)
WAN-2 (with DHCP)
LAN (192.168.1.254)
how can posibale to load-balance with this type of network
jwcn
Re: Load-Balance with dynamic gatway setings
Wed Jan 09, 2008 6:12 am
wiki.mikrotik.com
sandov63
Thu Feb 21, 2008 12:11 am
I have the same question ,, i think theres nobody with knowledge of this in all over the forum?
i had posted this same question many times without response
Cuando la ignorancia se impone, la razon cordialmente cede el paso.
gmsmstr
Trainer
Trainer
Thu Feb 21, 2008 3:12 am
asssuming both gateways do not have the same network, then you should be able to use v3 interface routing option.
Dennis Burgess, MCTCE, MTCNA, MCTCTE, MTCWE, MTCNIE, A+, N+, MCP, MTCSE Mikrotik Certified Consultant / Trainer
Need Mikrotik Support: http://www.linktechs.net -- Link Technologies, Inc.
-- Author of "Learn RouterOS: Second Edition"
bunrsa
Wed Feb 27, 2008 1:55 pm
If you want to load balance wan connections take a look at the following wiki entry:
http://wiki.mikrotik.com/wiki/Load_Balancing_Persistent
However in your case you will need to use masquerading instead of source nat and you will need to use interface routing instead of next hop routing.
I.E. instead of:
/ ip route
add dst-address=0.0.0.0/0 gateway=10.111.0.1 scope=255 target-scope=10 routing-mark=odd
add dst-address=0.0.0.0/0 gateway=10.112.0.1 scope=255 target-scope=10 routing-mark=even
you would use:
/ ip route
add dst-address=0.0.0.0/0 gateway=wan1 scope=255 target-scope=10 routing-mark=odd
add dst-address=0.0.0.0/0 gateway=wan2 scope=255 target-scope=10 routing-mark=even
and with NAT, instead of:
/ ip firewall nat
add chain=srcnat connection-mark=odd action=src-nat to-addresses=10.111.0.2 to-ports=0-65535
add chain=srcnat connection-mark=even action=src-nat to-addresses=10.112.0.2 to-ports=0-65535
you would use:
/ ip firewall nat
add chain=srcnat connection-mark=odd action=masquerade out-interface=wan1
add chain=srcnat connection-mark=even action=masquerade out-interface=wan2
let me know if that helps
Akangage
Thu Feb 28, 2008 6:26 am
/ ip firewall nat
What is the differeny if we using
/ ip firewall nat
add chain=srcnat  action=masquerade src-address=[LAN/Local]
bunrsa
Mon Mar 03, 2008 9:17 am
2 things are different:
1. You need to use the connection marking: "connection-mark="
2. src-address=[LAN/Local] only works if your IP is static, the first question in this topic was about load balancing with DHCP / Dynamic WAN IP's.
BurstNET
Thu May 01, 2008 9:23 pm
Any update on how to do this?
SMA
fatonk
Thu May 01, 2008 9:53 pm
Yes bunrsa is right, you cannot use action=src-nat because then you will have to specify to-addresses=X.X.X.X and in your case you do not know which address you will get from DHCP, just use masquerade out the interface. So, just follow the bunrsa example and you will solve this issue.
Regards.
Faton
Users browsing this forum: Bing [Bot], Google [Bot], Paternot, renanme, robberer and 226 guests
