Cyclone
Load balance over same GW
Thu Jan 10, 2008 9:26 am
I have 2 pppoe connections dialing internet, now both point to same GW. I wanna know it this is possible? I cant think of a way for this to work.
cmit
Re: Load balance over same GW
Thu Jan 10, 2008 9:33 am
If you are using V3.x of RouterOS you can use interface-based routing for point-to-point links like PPPoE connections. That means, that you can just use the interface name as the gateway in your routing table, like this:
/ip route add dst-address=0.0.0.0/0 gateway=pppoe-out1
(Of course for load-balancing you would have to use some kind of routing rule, mangle or the like.)
Best regards,
Christian Meis
Cyclone
Thu Jan 10, 2008 9:47 am
Thanks cmit
sandov63
Thu Feb 21, 2008 12:14 am
cmit how i can do load balancing with failover with two adsl modems if it asign dhcp ips ?
can you give me an example?
Cuando la ignorancia se impone, la razon cordialmente cede el paso.
NetworkPro
Fri Jan 16, 2009 12:31 am
I hope routes work by interfaces. The 'DHCP' IPs are not playing any part then. I will have to try this soon with a customized load balancing example from the WiKi.
Anyone made it work with PPPoE connections?
wiki.mikrotik.com/wiki/NetworkPro_on_Quality_of_Service
Users browsing this forum: Majestic-12 [Bot], marioclep, mbovenka, siscom and 239 guests
