Zaymran Ansar
arp poisner
Sat Jan 12, 2008 11:33 am
hi,
i m having problem with arp poisner, i have a big net work and cannot make static entries,
my setup is, single Hotspoted Lan, auto DHCP, and with multiple internet gateway for different mangle rules for different ports, one is for http, and all other are on the other one.
need help
thanks
pokeman
Re: arp poisner
Sat Jan 12, 2008 7:32 pm
hello
go to your dhcp server and select add arp then disable arp request on your lan card then make a static entry for MT server at your client end
Zaymran Ansar
Re: arp poisner
Sun Jan 13, 2008 1:59 pm
hello
thanks for reply, But are u sure this will not make any different or make any effect on my routing rule for multiple gatways, like http traffic using different internet gateway, and all other are using the other one. I have three Ethernet card insalled, 1 is for LAN and two other r for WAN(multiple gateway)
pokeman
Re: arp poisner
Mon Jan 14, 2008 1:41 pm
yes zaymran its working with multipul gateway you are apply this rule on your lan interface.
Users browsing this forum: No registered users and 138 guests
