nowires
High CPU usage in RC14
Mon Jan 14, 2008 1:43 pm
I have upgraded three of my boards to rc14.
In one of these boards the CPU usage is always more than 60%, without traffic. It's very strange.
Can someone give me a help?
normis
Re: High CPU usage in RC14
Mon Jan 14, 2008 1:45 pm
are you sure no traffic? unplug cables.
also try to disable packages one by one, and see if one makes a difference.
uldis
Mon Jan 14, 2008 3:12 pm
From which version you upgraded?
Are you using Nstreme?
Do you see any performance degredation on your router?
vlada1
Mon Jan 14, 2008 3:55 pm
I also see on my routers with nstream-dual high cpu usage , from 30% it rase to 60%
also performanse on nsteam-dual is worse than ever.
i upgraded from rc12 to rc14 and
with rc12
RX/TX 25Mbps / 33Mbps
with rc14
RX/TX 11Mbps / 30Mbps
test was before upgrade and right after upgrade.
using P4 dual-core , 1Gb ram , 512 Flash disc , asus board
Atheros XR5 ,actually i think signal better with rc14 for some 3db
uldis
Mon Jan 14, 2008 4:07 pm
with rc12
with rc14
please provide us with the support output file from your router where you have slow perfomance. Send that file to support@mikrotik.com
nowires
Mon Jan 14, 2008 5:28 pm
I have upgraded from 2.9.50 and I'm not using NStreme.
One WDS station interface and other AP Bridge. No traffic and 50% and higher usage.
vlada1
Tue Jan 15, 2008 11:33 am
Ok
my rx / tx was on 5700 / 5580
when i set rx on lower freq it works ok ,
but question is , why on rc12 works ok on this freq. and on rc14 not
to make sure , i tested on other dual link with rc14 , and same situaton.
uldis
Tue Jan 15, 2008 2:09 pm
Ok
there is no change for Nstreme2 only using framer-policy=exact-size could crash with kernel panic.
Make the support output file from both versions using the same freqeuncy and when you are sending the traffic.
Users browsing this forum: AndyGs, jatoledano, lglinde and 204 guests
