c_studt
OpenVPN unknown auth alg
Tue Jan 15, 2008 5:54 pm
tried to setup openvpn between linksys wrt54g with dd-wrt (openvpn server OpenVPN 2.0.7) and RB333 with RouterOS 3.0.
The log at the Routerboard always says:
openvpn-out1: initializing...
openvpn-out1: dialing...
openvpn-out1: terminating... - unknown auth alg
openvpn-out1: disconnected
Tried with "sha1", "md5" and "none" always same message.
Log at wrt says:
TLS: Initial packet...
VERIFY OK: depth=1, ...
VERIFY OK: depth=0, ...
Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Connection reset, restarting [0]
when i use md5
Data Channel Encrypt: Using 128 bit message hash 'MD5' for HMAC authentication
with auth none:
Configuration of openvpn-server:
proto tcp-server
port 1194
dev tun0
keepalive 10 120
verb 3
cipher none
auth none
ifconfig-pool-persist /tmp/ipp.txt
push "route 10.4.0.0 255.255.0.0"
persist-key
persist-tun
status openvpn-status.log
ca ca.crt
dh dh1024.pem
cert server.crt
key server.key
Configuration RouterOS:
name="ovpn-out1" mac-address=00:00:00:00:00:00 max-mtu=1500 connect-to=xxx port=1194
mode=ip user="username" password="password" profile=default certificate=cert2 auth=none
cipher=none add-default-route=no
Connection works between the linksys wrt and debian etch (OpenVPN 2.0.9).
So is there a problem in configuration or with the openvpn versions?
christian
mipland
Re: OpenVPN unknown auth alg
Thu Jan 31, 2008 10:07 am
Post the openvpn.conf of your wrt router.
Bye
IZ3HAD, Mirco
c_studt
Thu Jan 31, 2008 11:28 am
it was in the post -> Configuration of openvpn-server.
here again:
proto tcp-server
port 1194
dev tun0
keepalive 10 120
verb 3
cipher none
auth none
persist-key
persist-tun
ca ca.crt
dh dh1024.pem
cert server.crt
key server.key
mipland
Thu Jan 31, 2008 1:26 pm
Sorry, i didn't understand it....i think the vpn server was on routeros.... Sorry but i never tried it, i ever used only openvpn on routeros side (or on linux, but with linux or windows client, never with routeros client).
Bye
IZ3HAD, Mirco
mrz
Thu Jan 31, 2008 2:06 pm
works for me ( linux server mikrotik client ):
Version OpenVPN 2.1_rc4 i486-pc-linux-gnu [SSL] [LZO2] [EPOLL]
Server config:
dev tun
proto tcp
ca ca.crt
cert server.crt
key server.key
dh dh1024.pem
port 1194
server 15.15.15.0 255.255.255.0
;client-to-client
keepalive 10 120
user nobody
group nogroup
persist-tun
persist-key
verb 3
log /var/log/openvpn/openvpn-server.log
log-append /var/log/openvpn/openvpn-server.log
cipher none
auth none
# cipher AES-256-CBC
# auth MD5
Mikrotik config:
/interface ovpn-client
add add-default-route=no auth=none certificate=client1 cipher=none comment="" \
    connect-to=xx.xx.xx.xx max-mtu=1500 mode=ip port=1194 profile=default user="user"
mygod100
Fri Jun 13, 2008 6:20 pm
to my ddwrt on belkin 7231-4 of
OpenVPN 2.0.9 mipsel-unknown-linux [SSL] [LZO] [EPOLL] built on Mar 12 2008
error come the same.
is this the openvpn version too old?
hjf
Wed Apr 29, 2009 6:52 am
I'm bumping this thread as I'm having the same trouble. I followed http://wiki.mikrotik.com/wiki/OpenVPN and I tried running MT as server an Linux as client and vice-versa. Is this a bug on RouterOS?
miro9970
Mon May 16, 2011 6:38 pm
I am to, have similar problem.
I try to connect to Mikrotik OpenVPN server from DD-WRT OpenVPN client.
Config is taken from working inviroment.
OpenVPN client doesnt complain about anything but in Mikrotik logs says "unknown auth alg"
hjf
Mon May 16, 2011 7:43 pm
This is a 3 and a half year old bug. Mikrotik isn't going to fix this, so I suggest you to use another VPN or ask the DD-WRT guys for help.
wifix
Fri Dec 21, 2012 12:59 am
SOLVED !!!
After 3 Weeks of fighting with the problem we finally find out the problem.
The problem is caused by the openssl library, that is too new and isn't supported by openvpn mikrotik server.
MT OpenVpn Server (like written in the WiKi) support OpenSSL ver 0.9.8 with Cipher BF algorithm inside.
Openwrt backfire 10.03.1 doesn't has inside the right version, and with no Cipher BF algorithm compiled inside.
So the problem is solved installing Kamikaze old version i successfull use 8.09.2, r18961, or you find the way to compile openssl from source enabling Cipher BF.
Bye.
Thomas
WiFiX.org
Italian Communication Solutions Provider
Fraction
Wed Jan 16, 2013 9:54 pm
SOLVED !!!
Bye.
Ouch.. Have been fighting with this long time, but that wasn't the solution I wanted to hear. :)
Need to find some another way to do VPN between MT and OpenWRT then, I don't want to do downgrade to Kamikaze..
Grrruk
Wed Jun 05, 2013 1:26 pm
SOLVED !!!
Bye.
Any news about this bug? We hit it hard today. I wish I knew about it before deciding between buying RouterOS device and building Linux box for OpenVPN termination!!!! This bug is 5 years old! Ouch. Unfortunately I can't backpedal on this piece equipment, it's alredy here and money paid, but I'm certain I will never ever buy any RouterOS-based device and will advice people against buying it. 5 years! Now I have a serious deadline and stuck with non-working solution :(
The worst part of this bug: time flows and manufacturers produce new small routers, openwrt evolves with them and today it's difficult to find new routers that could run old kamikaze firmware. Not in sufficient amounts of them in my case anyway. The gap is getting wider and wider with time.
Djlobster
Sun Dec 22, 2013 12:37 pm
Good day,I have mikrotik rb750gl with the OpenVPN server and the telephone Galaxy 3 with OpenVPN Client (https://play.google.com/store/apps/deta ... eb.openvpn)
't associate these 2 devices on the VPN so I was told that in Mikrotik old libraries Opensll --- I have firmware V6.7 -- I was told that this firmware Openssl 0.9.8 --it's 2005,and today already have Openssl 1.0.1, --- and Android does not understand the old libraries of Openssl ))) please tell me what should I do??? and why in the new firmware de add new Openssl library ? thanks in advance!
Enot
Tue Dec 31, 2013 1:41 am
Install normal and full OpenVPN server in MetaRouter with OpenWRT image... OpenVPN integrated in Mikrotik will give you only problems... Mikrotik team don't like OpenVPN, no one know why... it's biggest secret on this forum. :lol:
RB951G-2HnD v6.7
chriswyth
Sun Apr 20, 2014 10:39 pm
tja, well, now in 4.2014 there seems to be still the same probelm when trying to connect to an openvpn server 2.1.4-3 on openwrt. Is there a clean solution without downgrading the server? And (hahaa), I got an RB SXT with Level 3 licence ..what a joke!!
Any good news on flashing OpenWRT ? sh** (sorry n'est-ce pas:)
jpillora
Fri Jul 18, 2014 5:39 am
July 2014 (v6.15) and still getting
. Please bump version of OpenVPN.
jarda
Sat Jul 19, 2014 12:01 am
The second biggest. Maybe. The first is the Dude.
cecelia
Mon Dec 08, 2014 12:20 pm
I am using trusted VPN software on my blackberry for along time without any connection problems. I suggest trying it for free http://www.vpnfaqs.com/2014/11/comparis ... y-and-vpn/
ivan07
Wed Mar 25, 2015 1:54 am
Same problem with Mikrotik OVPN Client in 6.27 :shock:
Is there any solution without downgrade?
Users browsing this forum: doman, doush, faxxe, Google [Bot], mkx, MSN [Bot], steen and 162 guests
