Rahulncc
2 wan ip 1 gateway 1lan
Thu Jan 17, 2008 4:11 pm
what i want to do is use 2 wan ips both pointing to a single a gteway the diffrence between the two ips is for example ip1 is 128kbps and ip2 is 1024 kbps
so when the router send packets to the gate way it should send 4 through ip2 and 2 through ip1
any pointers will be a grate help
jwcn
Re: 2 wan ip 1 gateway 1lan
Sat Jan 26, 2008 5:34 pm
Read the manual on load balancing
sandov63
Wed Feb 20, 2008 11:50 pm
A question for you,, how to do load balancing with failover with 2 adsl modems if it asign ip dhcp address?
Cuando la ignorancia se impone, la razon cordialmente cede el paso.
Chupaka
Sat Feb 23, 2008 1:19 am
as a rule, gateway address do not change =) so don't worry about dhcp
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
Users browsing this forum: Baidu [Spider], ilium007, iperezandres, miroslaw, wispmikrotik and 202 guests
