MUM Europe 2020
jacoblydon
what is the best setup for a N-Streme Dual link?
Thu Jan 24, 2008 6:10 am
I need to push a 20meg fiber connection about 3 miles point to point. I haven't used N Streme yet. I will probably use 29 db solid dish with RB 532a or RB333 and 8602+S on both sides. Some suggestions?
sergejs
Re: what is the best setup for a N-Streme Dual link?
Thu Jan 24, 2008 8:15 am
There is not too much configuration settings for Dual Nstreme,
http://www.mikrotik.com/testdocs/ros/2. ... php#4.13.4
Make sure you are using big enough gap between transmit and receive frequencies, as well make sure antennas are separated with maximum distance between each other.
RK
Long time Member
Long time Member
Thu Jan 24, 2008 1:54 pm
If it's only 20 Mbps, you should be fine with just one link.
Users browsing this forum: orionix and 167 guests
