uldis
RouterOS v3.1 Released - Wireless disconnection issue solved
Thu Jan 24, 2008 4:23 pm
RouterOS v3.1 has a fix for wireless disconnection problem, that was happening after upgrade from v2.9 to v3.0. All that had those issues, please upgrade to RouterOS v3.1.
What's new in 3.1:
*) fixed wireless reassociation issue;
*) added support for Novatel Wireless Merlin XU870;
*) added support for nForce Ethernet cards;
*) fixed bug - user manager database in-use counter was wrong
     for database size over 21 MB;
*) console - fixed parsing of alphabetical operators ('and', 'or', 'in') in
    expression context, this also fixes default configuration revert script;
*) fixed TKIP on RB300 and RB600;
*) fixed ipv6 firewall connection-state matcher;
*) improved WinBox connection speed & memory usage;
*) report correct tcp-state for firewall connections;
*) fixed ppp user names in ip accounting;
*) fixed via vt6122 (rb600 ether3) driver: multicast packet receiving
   did not work properly;
*) user manager - voucher template supports kb/mb/gb for
    download/upload/transfer limit values;
*) added ":led user-led=[yes|no]" command for RB100/RB400/RB500 series;
alex_rhys-hurn
Re: RouterOS v3.1 Released - Wireless disconnection issue solved
Thu Jan 24, 2008 10:26 pm
What exactly ws the problem that is observed? I have a disconnect problem but am not sure of it is the one resolved here....
alex_rhys-hurn
Fri Jan 25, 2008 7:24 am
I am asking about the wireless disconnection problem.
The problem I had was something about a key update problem.....
Trisc
Fri Jan 25, 2008 11:50 am
x86 version of 3.1 appears to be an invalid torrent file. The other versions download OK.
normis
Fri Jan 25, 2008 12:09 pm
I tested and it works fine with this one:
http://www.mikrotik.com/download/router ... .1.torrent
Trisc
Fri Jan 25, 2008 12:56 pm
No luck here. μTorrent says its an invalid torrent file but the Mips torrents worked OK...
Gerard
Trainer
Trainer
Fri Jan 25, 2008 5:13 pm
X86 not working for me either with Azureus..
-Gerard
normis
Mon Jan 28, 2008 8:59 am
MD5 of this attached file is: fe412e573d5122c5efe9825327b67684
does it match?
routeros-x86-3.1.torrent
md5sums-1.2.zip
Gerard
Trainer
Trainer
Mon Jan 28, 2008 4:39 pm
The file from the forum works fine..
I compared the md5's on 3 computers I downloaded the .torrent on last week and they all matched each other but did not match the forum file. I then redownloaded the .torrent from the website and it works fine now too..
All I can think is that the proxy you use was serving an incomplete version of the x86 torrent for a while.
Thanks,
Gerard
normis
Tue Jan 29, 2008 2:11 pm
yes, it probably was cached somewhere with some missing bits. that's why we made an MD5 section on the download page now - you can check if the sum matches, and so make sure that the download is not corrupted or messed with.
GWISA
Wed Jan 30, 2008 10:24 am
I've had some problems when moving (dragging) firewall rules on 3.0 in Winbox - their settings revert to a default of 'prerouting' and 'passthrough'.
I seem to remember this was an issue in an earlier RC release - has this been addressed in 3.1?
normis
Wed Jan 30, 2008 11:20 am
let us know how to reproduce this. does it happen all the time? in our experimentations there are no such issues
GWISA
Wed Jan 30, 2008 4:02 pm
OK - create 1 new firewall rule (mine are in mangle) and apply/ok.
Create 2nd rule before moving the first, and it will glitch when you ok it - when it recovers, the rule defaults to prerouting and 'accept'.
Its now that strange things happen - if you select both rules and try to drag them together, it sometimes works, sometimes doesn't and sometimes defaults the settings.
GWISA
Wed Jan 30, 2008 4:12 pm
Trying to replicate a fixed method of this is very frustrating. I create a rule, move it, it gets 'stuck', then might jump into place. If I log out then in again, it doesn't always take my edits.
After trying this, the router PC has become unresponsive but still passing traffic... :(
System is AMD 1.8GHz 768Mb RAM, v3.1 x86
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot], raulico, svmk and 63 guests
