alexandrecorrea
routeros 3.0 or 3.1 not couting firewall bytes/packets
Sat Jan 26, 2008 11:57 am
Newer mikrotik version (tested 3.0 and 3.1) not couting packets and bytes at firewall rulles !!
see attached image !
the system is running x86 routeros 3.1
Aug
Re: routeros 3.0 or 3.1 not couting firewall bytes/packets
Sun Jan 27, 2008 6:03 am
I had the same problem. Found this in another post.
interface bridge settings set use-ip-firewall=yes
Aug
npbrasil
Sun Jan 27, 2008 6:52 am
Hi Alexandre, if the bridge setting don't work, make a clean install. Look my portuguese reply at http://under-linux.org/forums/mikrotik/ ... post299681
alexandrecorrea
Sun Jan 27, 2008 8:31 am
hello !!
i made a clean re-install. but.. same problem !!
soho
Sun Jan 27, 2008 3:19 pm
Hi Alexandre,
If you are using the bridge mode, the answer of the AUG is correct. In the button Settings of the Bridge USE IP FIREWALL checked and in CONNECTION TRACKING you should check ENABLED.
npbrasil
Sun Jan 27, 2008 3:50 pm
Ok, type in terminal: /interface bridge settings and print, type set use-ip-firewall=yes. Good luck. Boa sorte. PS: You should not load the 2.9 backup file after 3.1 installation. Test with fresh rules only.
alexandrecorrea
Sun Jan 27, 2008 8:57 pm
hello !!
thanks for support :)
now it´s working fine !!
regards !
Users browsing this forum: Bing [Bot], brixsat, Google [Bot] and 92 guests
