mietus
v3.2 released ;-)
Fri Feb 01, 2008 4:04 pm
What's new in 3.2:
*) ssh - use preshared key also when user name has login parameters;
*) added ":led user-led=[yes|no]" command for RB300/RB600 series;
*) graphing - bugfixes; health section restored;
*) fixed problem - /ip traffic-flow could crash router
*) fixed simple queue vlan matching
*) fixed ipv6 firewall counters
*) user manager - fixed bug related to download/upload counter overflow
in reports;
*) fixed problem - sometimes dhcp client could not renew lease
on wireless interface;
*) fixed problem - connection tracking entries could not be removed sometimes;
*) ospf - don't install AS external routes with local address as gateway;
*) ospf - fixed bug triggered by adding and removing same AS external route
on two routers; that route could always remain in OSPF routing table;
*) web proxy - compact flash and USB disks did not show up after reboot
on slow boards, fixed;
*) fixed wireless transmit lockup detection;
pedja
Long time Member
Long time Member
Re: v3.2 released ;-)
Sat Feb 02, 2008 10:33 am
I also dislike new version numbering scheme. MT has not get out of beta stage yet and it already wasted three version numbers. We will have version 4 in month or two if it continues in this way.
That is unfair.
When I bought v2 licenses it was clear that it covers substantial development time according to the way how versions progress. Not it looks like I am misleaded, and that I got much less than what I payed for.
skillful
Trainer
Trainer
Sat Feb 02, 2008 1:34 pm
Wau.. 7 more released and at the rate it is going probably 2 more month I need to buy a new license to upgrade to V4.
Who said version 3 will end at 3.9? After ver 3.9 we expect 3.10, 3.11 ........ 3.99. I think we still have a very long way to go before ver4.
ashish
Long time Member
Long time Member
Sat Feb 02, 2008 4:16 pm
I was expecting ver 2.9.99 :D , again we can't GUESS it goes up to 3.99, sometimes it start like 3.9.1 :lol:
Can some one explain the numbering system
- AP - ASHISH PATEL - 757 309 0236 -
dawam
Trainer
Trainer
Sat Feb 02, 2008 5:55 pm
ok, I hope your thinking is right, so we have a long way to go for a field usable version.
Its funny not only we have to guest how certain ROS function would work. we also would have to guest how a new version numbering works.
Chupaka
Sat Feb 02, 2008 6:35 pm
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
sawireless
Re: v3.2 released ;-) a lot of shit
Sun Feb 03, 2008 5:41 pm
We did an upgrade from 2.9.50 to 3.0 but did we have a lot of problem with this upgrade. We found that when we upgraded, the system would only allow some clients on, and the CPU usage went through the roof.
We have just done another upgrade with a base station and fond that it is also full of problem.
MIKROTIK what is going on ?????
MikroTik 2.9.50
MikroTik Login:
Rebooting...
Stopping services...
installed routeros-mipsle-3.2
enabled routing-3.2
Restarting system.
RouterBOOT booter 2.12
RouterBoard 532
CPU frequency: 264 MHz
Memory size: 32 MB
Press any key within 2 seconds to enter setup..
loading kernel from nand... OK
setting up elf image... OK
jumping to kernel code
Kernel panic - not syncing: No init found. Try passing init= option to kernel.
hulk-bd
Sun Feb 03, 2008 9:59 pm
I think Ver 3 is just fine, we should give time to MT Team to fix few bugs in Ver 3, and if they fixed their bugs for us and give that bugs free version in the web then we should be thankfull to them not to argue about it.
Thanks n Peace 8)
H Zahid
Don't worry, be happy :) .......
fosben
Tue Feb 05, 2008 2:40 pm
we upgraded some systems -rb112, rb133c to 3.1 from 2.9 and got trouble with them at once. They reboot frequently for no reason and according to log it was because of power outage (confirmed not to be the cause).
Edit: upgraded those to ver 3.2 and they now work as before :)
kdavid
Tue Feb 05, 2008 3:13 pm
My RB600 has this problem:
system,error,critical router was rebooted without proper shu
tdown by watchdog timer
What is it meam
fosben
Tue Feb 05, 2008 3:44 pm
What is it meam
http://forum.mikrotik.com/viewtopic.php ... t=watchdog
kdavid
Tue Feb 05, 2008 4:19 pm
What is it meam
It is OK, but I have disabled watchdog... And it reboot always the Ap each 1h 1,5h
fosben
Tue Feb 05, 2008 7:59 pm
I guess you have uncheked watchdog, but have you also removed the ip address that it was set to ping ? If not, do that too.
Hellbound
Long time Member
Long time Member
Wed Feb 06, 2008 10:57 am
is this bug still there? I saw it first on 2.8
fosben
Wed Feb 06, 2008 4:11 pm
I got a new "problem" after installing v 3.2. Those running v3.2 is not discovered using winbox or neighbour viewer.. Anyone else noticed this ? winbox/telnet connects normal if I type in ip..
BrianHiggins
Long time Member
Long time Member
Wed Feb 06, 2008 6:34 pm
by default not all interfaces have discovery enabled on them in v3 for some reason , check /ip neighbor to make sure that discovery is enabled on the interface you are trying to connect to
rkorolev
Thu Feb 07, 2008 10:24 am
I'm using ROS on x86 PC.
Tried to upgrade 3.0 to 3.2 via combined package, the ROS stopped responding after reboot. The only thing in console is "Loading system".
Tried reinstalling 3.2 from CD and it didn't help. Reinstalling 3.1 help, it works again.
Does anyone have same problem?
kdavid
Sat Feb 09, 2008 4:14 pm
I had the same problem!
uldis
Tue Feb 12, 2008 1:34 pm
please both of you who has this problem, make the support output file from router when it is booting and working fine (v3.0 or v3.1), so then we could compare and look why it isn't booting the new version. Send those files to support@mikrotik.com
uldis
Tue Feb 12, 2008 1:47 pm
what interfaces you had in your router?
Are those interfaces enabled in 'ip neighbour discovery'.
rkorolev
Tue Feb 12, 2008 3:58 pm
I've sent a message to support 6 days ago, no reply.
Just sent a message again. supout.rif was making for almost 30 minutes and is 8mb in size.
Users browsing this forum: Google [Bot], MSN [Bot], nscheffer and 79 guests
