3000 clients at one broadcast domain does not sound like good configuration.
I think you have to consider better local network design and segregate 3000 users to smaller groups.
Who said that all 3000 users should be on the same subnet? How about VLANs?
I'm also interested in RB1000 performance with a large number of PPPoE clients with shaping/filtering.
well, PPPoE theoretical resource usage is shown at the link.
Anyway additionally RADIUS server will be required for PPP database, since local PPP secret database is designed for 50-70 clients.
Have not tested the 1000 yet, but a single core 3gig system can handle 2700 PPPoE sessions+.. Multi-core will change that as well. See just under a 50% gain when dual-cores are used.
Dennis Burgess, MCTCE, MTCNA, MCTCTE, MTCWE, MTCNIE, A+, N+, MCP, MTCSE Mikrotik Certified Consultant / Trainer Need Mikrotik Support: http://www.linktechs.net -- Link Technologies, Inc. -- Author of "Learn RouterOS: Second Edition"
