CarulloS
ROS 3.2 on x86
Sat Feb 09, 2008 3:07 am
I wanted to make sure folks were running this without problems. I have some systems I was about to upgrade but I'm holding until I hear back. This was from another thread but mixed with lots of other stuff...
I'm using ROS on x86 PC.
Tried to upgrade 3.0 to 3.2 via combined package, the ROS stopped responding after reboot. The only thing in console is "Loading system".
Tried reinstalling 3.2 from CD and it didn't help. Reinstalling 3.1 help, it works again.
Does anyone have same problem?
Thanks,
Scott
valens
Trainer
Trainer
Re: ROS 3.2 on x86
Sat Feb 09, 2008 7:56 am
I have several machines (PC, RB230) now running ROS 3.2 and have no problem.
rpingar
Long time Member
Long time Member
Re: ROS 3.2 on x86
Sat Feb 09, 2008 12:08 pm
I am running 3.2 on a dell poweredge860 without any issue.
There are two issues to be aware:
1. you have to disable the multi-cpu, because it is still unstable at kernel level;
2. you don't have to use the L7 filter, it is still unstable causing the crash of the router.
Regards
Ros
hulk-bd
Re: ROS 3.2 on x86
Sat Feb 09, 2008 1:21 pm
I'm running Ver 3.2 with multi-cpu on and layer-7 protocol used and facing no problem, it's working just fine.
Don't worry, be happy :) .......
magic
Re: ROS 3.2 on x86
Mon Feb 11, 2008 10:25 am
I have only 1 pc which don't boot with 3.2 after upgrade (I didn't tried other v3 version on this maschine). Also tried netinstall, but didn't help. After the Uncompressing linux...booting the kernel message the pc frozen. This worked very well with 2.9.x series.
Others works fine.
Config: Asrock p4vm890+Celeron 2.26GHz+192Mb DDR RAM+ Maxtor 20Gb HDD
Supout file sent to support.
Krisz
Krisztian Gancs
RLAN Internet Ltd.
http://www.rlan.hu
mrxbgd
Re: ROS 3.2 on x86
Mon Feb 11, 2008 10:45 pm
I have problem with 3.2 version on x86. Mashine freese after couple hour. We downgrade to 3.0 and everything works.
We sent supoat file.
csickles
Re: ROS 3.2 on x86
Tue Feb 12, 2008 12:02 am
I have 3 units on 3.2 no issues (other than a known CALEA issue that has been noted and is in a "fix process")..
Things that make you go "Hmmmmmmmm"...
Craig
redkurawa
Re: ROS 3.2 on x86
Tue Feb 12, 2008 4:55 am
I used one unit with v3.2, with multi-cpu enable, and it's work normal
rkorolev
Re: ROS 3.2 on x86
Fri Feb 15, 2008 10:22 am
I'm using ROS on HP Proliant DL140.
Neigher upgrade from 3.1 to 3.2, nor clean install of 3.2 from CD works.
csickles
Re: ROS 3.2 on x86
Fri Feb 15, 2008 4:21 pm
Is the DL140 a "G1" ?
Craig
gmsmstr
Trainer
Trainer
Re: ROS 3.2 on x86
Sat Feb 16, 2008 12:06 am
We have about 30 systems running 3.2 already. No major issues expect the few that have multi-core issues with SMP. Turn off SMP for those and no issues as of yet.
Dennis Burgess, MCTCE, MTCNA, MCTCTE, MTCWE, MTCNIE, A+, N+, MCP, MTCSE Mikrotik Certified Consultant / Trainer
Need Mikrotik Support: http://www.linktechs.net -- Link Technologies, Inc.
-- Author of "Learn RouterOS: Second Edition"
rkorolev
Re: ROS 3.2 on x86
Sat Feb 16, 2008 11:16 am
There's a reply from support, that they fixed drivers in release of 3.3.
And there's more good news:
What's new in 3.3:
*) fixed bug - PPPoE server could crash when running on multiple cores;
Will try to upgrade on monday...
idelac3
Re: ROS 3.2 on x86
Sun Feb 17, 2008 10:14 am
But, did you install ROS 3.2 yourself or it was pre-installed?
gmsmstr
Trainer
Trainer
Re: ROS 3.2 on x86
Mon Feb 18, 2008 4:43 am
All installed myself, or upgraded myself.
Users browsing this forum: No registered users and 130 guests
