phmorris
v3.2 nforce
Tue Feb 12, 2008 12:07 am
does any one know a way to get my nforce 590 gig LAN to work it is showing up under the resources but is not listed as a interface.
nVidia Corporation MCP55 Ethernet (rev: 163) it is a dual gig adapter that is on a asus motherboard.
I noticed that others posted this problem but never came to a resolution
point
Re: v3.2 nforce
Tue Feb 12, 2008 7:23 am
similar situation:
MCP51 Ethernet Controller (rev: 163) Vendor ID: 0x10de Device ID: 0x0269
not work with ROS 3.2
normis
Re: v3.2 nforce
Tue Feb 12, 2008 11:50 am
make a supout.rif file and send to support please, we will check it out
npero
Re: v3.2 nforce
Fri Feb 15, 2008 11:50 am
All with nForce mainboard LAN wait for 3.3. :D I tested on couple nForce mainboard work.
Best reagrds...
phmorris
Re: v3.2 nforce
Fri Feb 15, 2008 6:41 pm
I am trying V3.3 this morning we will see what happens.
Well Both 10/100/1000 network adapters came right up on the install.. dang you guys are great . Thanks alot for the quick resolution. I am not worried about the routerboard 44 card not installing properly now that i have both of those interfaces up. if you want i could try loading that card just so i could get the support.rif back you you all ...
Thanks again
-Phil
Users browsing this forum: dekana, ruksartbneha, sindy and 55 guests
