MUM Europe 2020
fosben
2x rb 333 problem [solved]
Tue Feb 12, 2008 4:06 pm
I got 2 new 333 boards yesterday... Problem is I cant access them. Poe/ether1 port doesnt connect at all on one card (cable unplugged), but ether2 works.
I then did a discover in winbox, found mac and ip 0.0.0.0. When I tried to connect I get the error "could not get routeros.dll". I then tried to mac telnet it, but I get connection timeout.
Then I tried to go to serial console and reset configuration, but it didnt help me at all. Any suggestions ?
Edit:
Netinstall tested.. so far no success.. I get this over and over..
Press any key within 2 seconds to enter setup..
trying bootp protocol............................... OK
Got IP address: 176.16.0.5
failed to resolve mac address
kernel loading failed
InoX
Re: 2x rb 333 problem
Tue Feb 12, 2008 8:49 pm
I think the boards were not new :lol:
Tanker
Wed Feb 13, 2008 10:53 am
Connect the RB333 to a working RB (any flavour) on the Ethernet Port and MAC Telnet into it....
Once you're connected
/system reset-configuration
Once it re-boots you will be able to access the board on either interface discovery by MAC Address
T
sergejs
Wed Feb 13, 2008 12:59 pm
fosben,
do you use the latest Netinstall version ?
try to isolate router and computer from other network and run directly netinstall between them.
fosben
Wed Feb 13, 2008 1:39 pm
new day, fresher brain...
As I was reading my post again today I noticed that I had set the boot ip to 176.16.0.5 and not to 172.16.0.5. So it couldnt resolve the mac. Today I set both in same range and tried it again. It failed for about 10 minutes, but suddenly it got ip and resolved mac. I managed to install both 333's with routeros 3.2 and now they both work like they should :)
Users browsing this forum: almdandi, fedus and 141 guests
