dmelis
web proxy error
Sat Feb 23, 2008 4:38 am
i need help, have routeros x86 3.1 webproxy enabled and found this:
web-proxy error stat(´var/cache/e/10/e1096999319d7f4cf10d6fef265f05b7´) failed:Input/output error
system unstable and fix temporary disable weproxy.
Any have this problem??
thanks
npbrasil
Re: web proxy error
Sat Feb 23, 2008 8:27 am
Yes, i have this problem in 3.3. I sent an supout to the support, but no reply up to now. Tip: check your hard drive and try upgrade to 3.2
hulk-bd
Re: web proxy error
Sat Feb 23, 2008 9:07 am
Check your HDD > /system check-disk
I had that kind a problem too and I done check disk then it was solved.
Don't worry, be happy :) .......
Users browsing this forum: domon, Majestic-12 [Bot], ochaconm and 53 guests
