karo84
Simultaneous-use is a Problem or a Bug For MikroTik?
Tue Mar 11, 2008 10:15 pm
Hello
I'm Very glad to introduce you to my problem.
I'm using Radius Server (Freeradius), everything is ok, but I have problem limiting SAME logins.
A username can be used to connect simultaneously.
I have enabled the simultaneous-use option in Radius server.
But I'm having a lot of problems, because some users can connect, but
the others (many of them) cannot connect. In logs of Radius Server I
see
<<Sending Access-Reject of id 180 to 192.168.254.254 port 4938
        Reply-Message := "\r\nYou are already logged in - access
        denied\r\n\n">>
Message.
On my Radius Server I have set the "simultaneous-use := 1"
Please Tell me why?,
Why the new connecting user must have any port using On NAS ?.
I'm waiting For Your Reply.
We are using ROS 2.9.51, May be it is a bug or something like it?
Thanks With The Best Regards
Karo Aznavuryan
bokili
Re: Simultaneous-use is a Problem or a Bug For MikroTik?
Tue Mar 11, 2008 11:15 pm
It works in Radius Manager without a problem with mt 2.9.51, so I suppose that this is not problem in mikrotik.
karo84
Tue Mar 11, 2008 11:31 pm
Did You use "Simultaneous-use" option for groupe or for a user, ?
I think, there must be some differences.
I have tried the Radius Manager. In RadMan is used "Simultaneous-use" for each user, according to this the number of rows will grow up in MYSQL Database, but I want to use this option for the given groupe.
Karapet Aznavuryan
savage
Wed Mar 12, 2008 9:27 am
There, is MUCH more than that required. Please read the documentation provided in FreeRadius about Simultaneous usage, and specifically, implement the checkrad scripts.
Regards,
Chris
Users browsing this forum: CZFan, yoliveras and 85 guests
