MUM Europe 2020
serenida
prism 2511mp plus problems
Mon Apr 07, 2008 1:48 pm
I have a great problem when I use a pc with a dual core processor and a mikrotik relese 3.6 becouse the minipci prism 2511mp plus after few seconds doesn't make the
pppoe autentication can I have an help from you!!?? another problem is that the wep
encryption doesn't work well by some new tipe of client :lol: :lol:
best regards
EgyCom
Re: prism 2511mp plus problems
Mon Apr 07, 2008 1:53 pm
disable Multi Core support in ROS
/system hardware
set multi-cpu=no
and also wait till ROS 3.7, it should release today
serenida
Wed Apr 09, 2008 12:04 am
hi,
I have installed the ros 3.7 but the problem there is always.
if I disable the multi-cpu instead it correctly works the minipci prism!
how can I resolve?
regards
serenida
EgyCom
Wed Apr 09, 2008 4:41 am
i don't understand you, if you disable multi-cpu , your card work or not ?????
serenida
Wed Apr 09, 2008 9:34 am
hello,
yes when I disable multi-cpu the minipci prism works very well,
but how I can do for use the multi-cpu by this minipci prism, it is a bag
of ROS 3.7 ??
best regards
serenida
Alessio Garavano
Fri Jun 06, 2008 4:11 pm
Hi, i don't sleep in all night! :shock: because yesterday upgrade all a network to 3.10 to do L2 Mesh Protocol, but in all RBs with a Prism Card this stop working, no wireless signal, traffic, connections, nothing? try downgrade to 3.9, reset-config of the card to default, but nothing, the card is not responding nothing in tx/rx
Downgraded to 3.2 all work again :)
Serious problem in lastest versions (i think post-3.7) and Senao 2511 or PRISM Card!
I was the first testing this? :x fuc......
Alessio Garavano
http://www.isparg.com.ar
Panos2000
Sat Jul 05, 2008 6:40 am
You're not alone! All of our network consists of Senao 2511 cards for Access Points (We use CM9 only for backbone). Performance is terrible... :( Maximum download speed around 160-170K. I really hope Mikrotik comes up with a fix soon. We can't really afford to change all of our Senao just because ROS3 doesn't support it!
che
Mon Jul 14, 2008 10:55 am
Maybe this is the explanation:
*) updated drivers;
Users browsing this forum: Google [Bot], MSN [Bot], Znevna and 86 guests
