Hi all,
I have a very serious problem with installing a 3g modem huawei 660A pcmcia on a rb230.-
When I plug modem in a pcmcia slot I'm having random reboot before modem connect.
When I plug modem in a pci-pcmcia adapter slot the system hangs.
After probing with several linux kernels versions nothing changed, same behavior.
E660A needs 3,3v with 750mA. Maybe the problem?
Regards.
dblackbeer
