thavinci
Another web-proxy bug... 3.7 x86
Wed Apr 23, 2008 7:08 pm
It seems some times, unexpected the proxy will die.
Pages return an error along the lines of "the proxy isnt excepting connections"
Reboot box fixes that.....
Any way to via scripting check running processes and restart if is it fails?
This is a serious issue...
BTW on version 3.7 x86.
http://www.thavinci.za.net
echo "Demo license expired!"
echo "Please reinstall the router."
echo
kill -WINCH 1
exit
karo84
Re: Another web-proxy bug... 3.7 x86
Fri Apr 25, 2008 7:07 pm
I have the same problem too.
Even I use redirects from IP>Firewall>nat>dst-nat to adresses to ports, NOT USING IP WEB PROXY feaure, I have that problem.
I have to reboot the Router (ROS 3,7) in order i works.
Before I use 2.9.51 here was no such problem.
thavinci
Fri Apr 25, 2008 8:32 pm
They have admited to the problem and have following response:
Hello Marcel,
Thank you for the support output file.
We are researching where could be the problem, the problem is related to routing
Regards,
Sergejs
echo
kill -WINCH 1
exit
thavinci
Sun Oct 26, 2008 11:44 pm
For those interested.
The problem "solved itself" , in later releases.
echo
kill -WINCH 1
exit
Users browsing this forum: No registered users and 146 guests
