Equis
Forum Veteran
Forum Veteran
Routes
Thu Apr 24, 2008 8:53 am
Hello
I have ospf running and it adds routes with a distance of 100
I added al2tp tunnel and added a route over that with a distance of one but the data still takes teh ospf advertised path :-(
Does anyone know why this would be?
Equis
Forum Veteran
Forum Veteran
Re: Routes
Thu Apr 24, 2008 9:14 am
Ok,
from what I can tell it favors smller prefixes, even if the distance is longer.
Does anyone know how I can fix this?
fatonk
Re: Routes
Thu Apr 24, 2008 10:35 am
I'm facing this same issue, and could not find a way to resolve it. I hope there is a way to do it in RouterOS.
awsmith
Re: Routes
Mon Apr 28, 2008 6:01 pm
Ok,
There's nothing to fix. That is how IP routing works. The router finds the most specific match for the address it's routing to. That's how a default route works ... it is the least specific possible prefix, therefore it is only used when no more specific route is in the routing table.
To make the prefixes match between your static routes and your ospf routes, either make your static routes more specific to match the ospf ones, or, use ospf summarization and have an area range match your static route.
fatonk
Re: Routes
Mon Apr 28, 2008 6:32 pm
Yes, but I do not want to advertise all the pppoe customers like /32, I want to summarize and these has to be fixed.
thanks
mrz
Re: Routes
Tue Apr 29, 2008 9:53 am
thanks
If you want to summarize pppoe /32 routes, then do as awsmith wrote - use ospf area range.
Users browsing this forum: PiGeonCZ, rezagolshan and 101 guests
