MUM Europe 2020
AsDsL
Loading system with Initrd, after Upgrade from 2.9 to 3.7
Tue Apr 29, 2008 4:49 pm
I have been reading about it in the forum, after that I can’t find a solution.
Is there a fix for it?
Is it a Kernel problem?
The Router OS is installed in a DOM, Tyan s5161, Pentium D 950, 2gb Mem. It works perfectly on other system AMD single Processor.
Thanks,
AsDsL
AsDsL
Re: Loading system with Initrd, after Upgrade from 2.9 to 3.7
Sun May 04, 2008 6:12 am
Oh God!
where is MT Tech Sup?
jwcn
Sun May 04, 2008 7:07 am
savagedavid
Trainer
Trainer
Sun May 04, 2008 11:34 pm
Do you have a backup of the router? If so you can do a netinstall onto the CF using a cF adapter and any windows machine running Netinstall. This should repair the problem as it initiates a fresh install when the CF is first booted on the target machine. It wont affect the license either. Afterwards you can restore from backup. I have found certain (x86) hardware does not like the upgrade.
You can also try the same directly on the target machine using a CD install. It will also retain your license using this method.
savagedavid
MTCE+T (MikroTik Certified Everything + Trainer)
MikroTik support and training in South Africa
http://www.mikrotiksa.com
david [at] mikrotiksa dot com
Users browsing this forum: ilja, MSN [Bot], naxos and 122 guests
