medube
Redirecting to URL after Hotspot login...
Tue Mar 15, 2005 2:40 am
Hi All,
Does anyone how to set config, so that once user logs in using Hotspot, he is automatically redirected to our web page and not original page requested? I have tried editing the login.html page changing the orig link to desired web page, but that hasnt helped.
Any suggestion is highly welcomed.
Medube
djape
Tue Mar 15, 2005 3:33 am
Try using webserver on some of your pc's (example 192.168.1.100),
then in MT dst-nat use this:
add src-address=192.168.1.0/24 action=nat to-dst-address=192.168.1.100
to-dst-port=80
All users will be redirected to your page.
Cheers...
medube
Tue Mar 15, 2005 12:04 pm
Hi Djape,
Thanks for the info, but I dont think you understood the question well. Now under hotspot when user obtains an IP, he/she opens up IE and requests for example http://www.google.com, he/she is automatically redirected to the hotspot login page. Once he/she puts in user name and pass and logs in, he is automatically sent to http://www.google.com. Now what I want is no matter what is requested, lets say http://www.google.com again, user will automatically be redirected to our webpage as first page after login.
I hope this paints a better picture.
Medube
djape
Tue Mar 15, 2005 10:23 pm
OH, well, sorry :( to much beer I guess :D
Hm? I must check with my partner, I am sure that he made this to work.
Be back with some useful info...
Cheers...
medube
Tue Mar 15, 2005 10:40 pm
Thanks for the help so far djape. I hope to be hearing from you very soon 8)
medube
bjohns
Wed Mar 16, 2005 1:30 am
http://www.mikrotik.com/docs/ros/2.8/ip/hotspot
To choose different page shown after login, in login.html change:
<input type="hidden" name="dst" value="%link-orig%">
to this line:
<input type="hidden" name="dst" value="http://your.web.server">
(you should correct the link to point to your server)
medube
Wed Mar 16, 2005 1:39 am
Did you read that part of my first message?
medube
bjohns
Wed Mar 16, 2005 2:34 am
No, but yes, it's the same problem I have run into. Try it with non-encrypted password set. I believe the hashing thingy overwrites it with the old. I've raised it with Mikrotik ages ago but haven't received a reply.
uldis
Wed Mar 16, 2005 11:48 am
We will change the documentation.
Current method when you change the login.html will work only in case of PAP authentication.
You should modify the alogin.html file and replace this line:
location.href = '%link-redirect%';
with this line:
location.href = 'http://your.web.server';
And also this line:
<td align="center" valign="bottom" height="50px">If still nothing happens, press <a href="%link-redirect%">here</a></td>
with this line:
<td align="center" valign="bottom" height="50px">If still nothing happens, press <a href="http://your.web.server">here</a></td>
medube
Wed Mar 16, 2005 6:19 pm
Thanx a lot Uldis, that really solved the whole problem.
Medube
Trisc
Wed Mar 16, 2005 9:10 pm
Following on from this thread - is it possible to do an HTTP post of username/password from a different server direct to the hotspot's alogin.html page?
So when a customer payment has been authorised on our payment server it could populate a form on that server with username and password that posted to the hotspot's authorisation page.
What elements would be needed on the form?
Trisc
Users browsing this forum: ramirez, skylark, SpartanX and 203 guests
