EgyCom
ROS v3.8 is out
Thu May 08, 2008 5:08 pm
ROS v3.8 is out
What's new in 3.8:
*) fix B mode rate reporting for Atheros 5211 cards;
*) IPv4-compatible addresses as IPv6 route gateways now require
   manually specified interface;
*) fixed removing external routes from OSPF;
*) added initial version of layer-2 mesh routing protocol;
*) fixed problem - OVPN server sometimes crashed;
*) fixed problem - torch could fail to aggregate connection data;
*) fixed problem - RB500 on high ethernet load rebooted sometimes;
*) fixed problem - if PPP (ISDN) client requested it's own address, then server
   did not report it in logs correctly;
*) fixed problem - if PPP (ISDN) client has it's own address, it was
   not used allways as on-demand ip address;
*) fixed problem - PPPoE, PPTP & L2TP stops receiving packets, if
   MRRU is set and multiple packets get lost;
*) added support for Intel Gigabit PCI-Express cards;
*) fixed problem - RB433 did not work with v3.7;
Alessio Garavano
Re: ROS v3.8 is out
Thu May 08, 2008 6:59 pm
More data about this new item?
how is better for mesh???
MME...?
WDS Dynamic-mesh with rstp?
Alessio Garavano
http://www.isparg.com.ar
Gerard
Trainer
Trainer
Re: ROS v3.8 is out
Fri May 09, 2008 5:26 am
Certified Mikrotik Trainer
rodneal
Re: ROS v3.8 is out
Fri May 09, 2008 7:58 am
Yes it is - and the interfaces disappear after 45minutes - be aware of this
Users browsing this forum: Bing [Bot], eworm, Google [Bot], jvanhambelgium, markos222, Moomoo71, msatter, sindy, Znevna and 90 guests
