MUM Europe 2020
cuccio
Trainer
Trainer
problem whit format cache-disk
Tue Mar 15, 2005 10:04 am
" web-proxy error = web-proxy error while formatting harddrive : failed to format drive "
with 2.9beta14 in P4 Xeon 2,4Ghz Ultra ATA disk 40Gb.
100% CPU load during formatting.
The cache is secondary master.
Bill
Tue Mar 15, 2005 12:15 pm
I received a similar error when setting up my web-proxy. Just enable it and it should work. It will take it a little time to setup the file system on the drive. How much of the drive you can use will depend on how much RAM you have installed. I have a 40GB ultra DMA drive with 512MB RAM on a 1Ghz P3. My maximum cache size is 29949MB (29.9GB).
djape
Tue Mar 15, 2005 11:30 pm
@Bill
Tell me mate, did you ever come close to 20gb of cache without expiriencing problems with surfing??
Cheers...
Bill
Wed Mar 16, 2005 12:12 am
It got up to 6GB with no problems. I cleared the cache and started over when I upgraded to 2.8.24 about 3 weeks ago. It's back up to 3GB now. So far, there are only 7 PC's using the proxy, so it doesn't accumulate very fast. I put a 40GB drive in because the was the smallest I could buy. The 29GB size limit is due to only having 512MB of RAM in the router.
hci
Long time Member
Long time Member
Wed Mar 16, 2005 6:36 am
Have you experienced problems with over 20Gbyte in cache?
Matt
Users browsing this forum: Google [Bot], MSN [Bot], NetWorker, sstefanov and 45 guests
