mxena
Accounting is useful?
Mon May 12, 2008 8:55 pm
I'm using simple queues to limit the amount of traffic per user-day. Every 20 minutes I check if a user has exceeded 100MB of traffic in that interval and then I limit the rate to the half. Then, at 5:00 a.m. I reestablish the queues.
The problem is that Is lose the total amount of traffic of every user. I would like to know, let's say, the traffic that a user uses in a month. I thought that the solution would be the Accounting in MT but I was surprised when I read that "The maximum setting is 8192 IP pairs." Just 8192 pairs? 8192 pairs would be used just by a single user if he runs an Ares, isn't it?
Is there any other mechanism to know the total amount of traffic per user?
Thanks,
Miquel.
Chupaka
Re: Accounting is useful?
Mon May 12, 2008 11:05 pm
yes. R.A.D.I.U.S.
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
Equis
Forum Veteran
Forum Veteran
Tue May 13, 2008 2:24 am
I dont know why they say 8192
becuase you can get way morem try and see
mxena
Tue May 13, 2008 11:36 am
Thanks everybody,
I will try to arrive to this limit but the problem is what I wrote, even 80,000 wouldn't be enough for an user running Ares.
Note for Mikrotik: Wouldn't it be more useful if You were able to account traffic limiting it with a mask?
About Radius: radius is a good solution depending on what kind of network You are implementing. In this case traffic accounting is just an extra.
ste
Tue May 13, 2008 12:19 pm
Yes. Real limit is 260000. We do accounting based on this.
Works fine so far.
Stefan
mxena
Tue May 27, 2008 1:15 pm
Thanks, I will try.
Users browsing this forum: Baidu [Spider], Bing [Bot], Google [Bot] and 43 guests
