MUM Europe 2020
boardman
Two BUGS *** I Believe *** in configuration exporting engine
Wed May 21, 2008 2:07 am
I Believe there is a bug in version 3.x (tested in v 3.9), while exporting configuration in queues simple if there are any queues with unlimited settings in Burst Limit or Burst threshold or 0 in seconds this is what's gets exported:
add burst-limit=/1536000 burst-threshold=/256000 burst-time=/32s comment="" \
direction=both disabled=no dst-address=0.0.0.0/0 interface=all \
limit-at=256000/256000 max-limit=512000/512000 name="Global Forwarding @ \
ITC - 512K" parent=none priority=5 queue=default/default \
target-addresses=12.52.84.35/32 total-queue=default
As you can see:
burst-time=/32s
If you copy paste this exported queue simple and paste it into a routeros your gone a have three errors ... I don't know but this might be a bug in the exporting engine.
There is another bug/error in exporting engine:
If you /ip firewall layer7-protocol
then export file=l7p for example and later you copy paste that into another router you will end with a bunch of errors because Mikrotik is confusing symbol \ with the \ contained in the regular expressions of the L7 protocols.
Any comments about this? Am I wrong?
Best Regards
Jorge Boardman
jwcn
Re: Two BUGS *** I Believe *** in configuration exporting engine
Wed May 21, 2008 4:17 am
Jorge,
Do you have any idea how many "bug" topics you have started? Starting to wonder about user error, seriously!
boardman
Wed May 21, 2008 8:37 pm
Jorge,
Yes, three (including this one) for RouterOS and one for The Dude...
From those, one for RouterOS turned to be actually a bug (bios), and the one for The dude was and still a bug.
I really do not understand the point of your comment, but I can assure you, I do not post in this forum without a reason, I am NOT a Mikrotik expert but I have been using it probably for the last 7 - 8 years, and I have installed and keep running probably more than 200 systems with RouterOS.
But, yes you are right, it can be an user error. Since I am not such an expert, if I found something that's unusual or beyond my limited knowledge, I post that here... mainly for three reasons:
1- Feedback that may help RouterOS people.
2- Help fellow forum readers
3- Learn
But, jwcn if you really think I am waiting somebody else's time ... I am sorry .... I'm sorry for my lack of knowledge, I am an electronics and communications engineer but when I was in school the most advanced computer was an apple II with barely or no networking, from that point till today everything I have learned has been by myself, so sorry for my lack of knowledge.
I do not want to sound rude but If you do not like what I post ..... PLEASE DO NOT READ IT...
Regarding this issue, I don't know but exporting a simple queue and copy paste it causing an error it is a bug to me.
Best Regards
Ing. Jorge E. Boardman
http://www.laredonet.com
MEXICO
changeip
Wed May 21, 2008 9:14 pm
it probably is a bug, email details with a supout to support at mikrotik.com.
Sam
Colo and Wholesale Bandwidth Available! Sales at SanDiegoBroadband dot com
madnet
Thu Jun 26, 2008 12:02 pm
CONFIRMED BUG - as of v3.x beta!
I have spent many hours testing exports and scripts on MT and I can confirm 100% that it is a BUG but very easy to solve.
For those who haven't noticed since v3.x MT has strictened syntax so if you try to for example
[root@mtv3x] /queue/simple disable [find target-address=192.168.0.1]
it won't do anything, but
[root@mtv3x] /queue/simple disable [find target-address="192.168.0.1"]
will do the trick.
Same thing apllies to queues, so if you have:
add burst-limit=/400000 burst-threshold=/200000 burst-time=/2h comment="" \
    limit-at=300000/300000 max-limit=300000/300000 name="someuser" \
    parent=none priority=8 queue=default-small/default-small \
    target-addresses=192.168.216.14/32 total-burst-limit=400000 \
    total-burst-threshold=200000 total-burst-time=2h total-limit-at=400000 \
    total-max-limit=400000 total-queue=default-small
will FAIL and this is ACTUAL EXPORT from v3.7 on RB333, but
add burst-limit="/400000" burst-threshold="/200000" burst-time="/2h" comment="" \
    direction=both disabled=no dst-address="0.0.0.0/0" interface=all \
    limit-at="300000/300000" max-limit="300000/300000" name="someuser" \
    target-addresses="192.168.216.14/32" total-burst-limit="400000" \
    total-burst-threshold="200000" total-burst-time="2h" total-limit-at="400000" \
    total-max-limit="400000" total-queue=default-small
will WORK every time.
So, guys from MT please make command syntax even more strict so that users must enter [variable_name]="[parameter]" for EVERY variable and implement that in EXPORT command.
Tanker
Fri Jun 27, 2008 4:55 pm
The only bugs I find are on my dog.... maybe I'm just too stupid...
I just do a backup off the old stuff and restore on the new stuff (ie: RB600 from RB500) and haven't had ONE issue...
Like I said - maybe a little dim.... but thing I can tell you is I DO NOT go LOOKING for the tinyest weeenyest little bug in ROS everytime a version hits the scene... btw - those fancy xxCO boxes you can buy come with a MANUAL on how to circumvent the KNOWN bugs... sheeesh!!!!
Give me ROS on a RB anyday... OK back to the dog....
T
boardman
Sat Jun 28, 2008 8:10 pm
T
Yes please go back to your dog...
jwcn
Sun Jun 29, 2008 7:00 am
He made a valid point...
boardman
Sun Jun 29, 2008 6:22 pm
What's new in 3.10:
*) added Multilink PPP to PPPoE client - just specify multiple interfaces
to enable it;
*) added ability to add dynamicly PPTP, L2TP & PPPoE client addresses
to firewall address-list, specified in ppp profile,
or via RADIUS in Mikrotik:19;
*) added address-list attribute support in user-manager;
*) added fan control for RB433;
*) console:
fixed 'interface wireless print detail', now shows the same output as
'interface wireless print basic';
fixed print to file, now writes complete contents, fixed resource leak;
show name of running scripts in '/system script job', update
'last-started' value;
could not use item names for '/interface ovpn-server' and
'/interface ovpn-client', fixed;
fixed problems with export:
some settings were not included in full export, such as
'/interface wireless nstreme');
some settings had duplicate entries with an error, such as
'/system ntp client' when ntp package was enabled;
long parameter values were incorrectly split across multiple lines;
export now quotes all values that are split across multiple lines, it
also adds line split before all newline characters, which improves
readability of exported script sources;
Tanker
Mon Jun 30, 2008 3:29 pm
What's new in 3.10:
to enable it;
*) console:
Like I said.... give me RB anyday...
You could of course revert to 10x price xxxCO product - where you require a PhD to operate the stuff..!!! Nah.. ROS rocks..
T
Users browsing this forum: Bing [Bot], Google [Bot] and 68 guests
