normis
New MPLS and Routing packages
Thu May 22, 2008 1:26 pm
We have added mpls-test and routing-test packages to the download page. They extend the functionality of already existing packages in the areas of MPLS and BGP. Please test these new packages:
http://www.mikrotik.com/download.html
changeip
Re: New MPLS and Routing packages
Thu May 22, 2008 6:56 pm
can you outline some of the changes in -test packages ? Why the need for another branch rather than releasing with normal packages? I am just curious as to what the major changes are.
Colo and Wholesale Bandwidth Available! Sales at SanDiegoBroadband dot com
rpingar
Long time Member
Long time Member
Thu May 22, 2008 11:46 pm
i am interested into the new BGP features.
is the time about multiple recursive next-hop?
regards
Ros
normis
Fri May 23, 2008 10:12 am
http://wiki.mikrotik.com/wiki/Layer-2_r ... h_networks
http://wiki.mikrotik.com/wiki/Virtual_R ... Forwarding
http://wiki.mikrotik.com/wiki/MPLS_TE_Tunnels
http://wiki.mikrotik.com/wiki/BGP_based_VPLS
Basically all changes and fixes in the MPLS package that are mentioned in the Wiki articles are only in the new MPLS test package, so if you use MPLS, you MUST use the new package.
Alessio Garavano
Thu May 29, 2008 9:30 am
Links broken... i need download theses test packages, i am having serious problems in MPLS with regular packages.
Can you send me?
Thanks!
Alessio Garavano
http://www.isparg.com.ar
normis
Thu May 29, 2008 9:45 am
sorry, links fixed
Alessio Garavano
Thu May 29, 2008 9:47 am
Thank you Normis,
Best regards,
Alessio Garavano
Alessio Garavano
Thu May 29, 2008 10:14 am
It's possible to do MPLS with MME? without OSPF or BGP?
Alessio Garavano
Mplsguy
Fri Jun 06, 2008 5:17 pm
It depends on what protocol is used for label distribution. LDP distributes label for each active route except BGP routes, so - yes, it will also distribute labels for MME routes. This in turn enables routers to MPLS switch packets along routes established (learned) by MME.
As to RSVP TE - only protocol for RSVP TE information exchange that RouterOS supports is OSPF. Still this does not mean that RSVP TE can not be used in network where routes are exchanged with MME - you just can not use CSPF - to have "constraint based path selection". Tunnel paths will be established over regular route towards tunnel destination (no matter what bandwith allocations are made on interfaces).
netrat
Thu Jun 12, 2008 3:21 pm
This might be a stupid question, but can you use MPLS and BGP in RouterOS level 4? BGP is only available in RouterOS level 5 and 6 right?
Mplsguy
Thu Jun 12, 2008 6:05 pm
It depends on system architecture - x86 does not support BGP in level 4, but RouterBoards do support. Wether BGP is allowed or not at any level, does not affect MPLS, but essentially you need level that supports BGP if your setup requires BGP (MPBGP).
Gerard
Trainer
Trainer
Fri Jun 13, 2008 6:24 am
Does this only go for new installs? I have a level 4 X86 system using 3.7 running full tables with two peers.. It was an upgrade from 2.9 though.. Now I'm a bit concerned about upgrading ROS or messing with bgp on that router..
-Gerard
Certified Mikrotik Trainer
ricky011
Tue Jul 15, 2008 1:37 pm
links are again broken for the beta test packages for the 400 series??
normis
Tue Jul 15, 2008 1:53 pm
sorry, fixed
archon
Wed Jul 23, 2008 8:08 pm
is Transparent AS working in MikroTik?
If not, are You planning to add thins functionality?
phendry
Fri Aug 15, 2008 1:53 am
Anyone know if you can use MPLS QoS with WMM?
Mplsguy
Tue Aug 19, 2008 6:50 pm
Depends on what you mean by "use MPLS QoS", but most likely answer is - yes.
See http://wiki.mikrotik.com/wiki/EXP_bit_behaviour and http://wiki.mikrotik.com/wiki/WMM
If packet is MPLS switched over WMM enabled link - either by "normal" hop or penultimate hop, WMM access category will be chosen based on EXP bits of received label (because EXP gets copied to "priority" field). In case packet arrives to router using MPLS switching and is further routed over WMM enabled link (router is egress for LSP), care must be taken so that correct "priority" is assigned to packet:
- LSP egress router must receive packet with label (this implies that explicit null label should be used by penultimate hop) - this will cause packet "ingress priority" to be set to value carried in EXP.
- correct firewall rule that sets "priority" from "ingress priority" must be configured.
Users browsing this forum: Baidu [Spider], DarkNate, Google [Bot], keshawnmc2007, krafg, sindy and 99 guests
