MUM Europe 2020
phil1995
Satellite Download Limits
Mon May 26, 2008 11:41 pm
Unfortunately I live in an area where satellite interenet is my only option. Under the rules of their business plan, I am allowed 1250MB (1.25 Gb)downloads per day without falling under their "Fair Access Policy" (FAP) limitations which disrupts my service for a minimum of 24 hours.
I would like to know how I can keep track of the download limits on a real time basis. I have seen tools such as TORCH that will allow me to monitor "real time", but as far as I can tell, it does not give me a cumulative total of the received transmissions.
Any advice here will be greatly appreciated. I need to develop a way of tracking and halting traffic when I approach this limit.
jwcn
Re: Satellite Download Limits
Tue May 27, 2008 12:23 am
Are you in the US?
phil1995
Tue May 27, 2008 12:27 am
Yes, I am in South Mississippi
savagedavid
Trainer
Trainer
Tue May 27, 2008 1:17 am
A real simple way would be to add a queue on the satellite interface - not perfect because it will lose the count if the board reboots, also it is (apparently) not 100% accurate. But for your purpose it should work fine.
savagedavid
MTCE+T (MikroTik Certified Everything + Trainer)
MikroTik support and training in South Africa
http://www.mikrotiksa.com
david [at] mikrotiksa dot com
WirelessRudy
Tue May 27, 2008 1:28 am
Are you in the US?
Some questions! :? :lol:
Do they count different there? confused by the usd maybe? Getting less each day for the same......
Sorry, its late here in euro land! :lol:
phil1995
Tue May 27, 2008 1:37 am
Thanks for your help. I added a simple que to the interface, leaving everything as default. I was lookin in the total statistics section and I see a "Total Bytes" field. Is this for download and upload or just download.
How do I monitor just the total bytes dowloaded.
Chupaka
Tue May 27, 2008 2:01 am
add firewall rule with action=passthrough (chain = prerouting, in-interface=your_sat_interface)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
phil1995
Tue May 27, 2008 2:10 am
chain=prerouting is not available.
Input, Output and forwarding are the only available choices.
Chupaka
Tue May 27, 2008 2:28 am
use mangle, not filter
jwcn
Tue May 27, 2008 5:01 am
Phil,
Email me. I have a solution for you that is probably cheaper and definitely better than Satellite. info at delmarvawifi dot com
savagedavid
Trainer
Trainer
Tue May 27, 2008 10:32 am
Using firewall passthrough / mangle will essentially do the same thing as a queue and with the same limitations (except it will use less resources). The queue is a lot easier to monitor in real time though.
savagedavid
Users browsing this forum: lweidig and 83 guests
