MUM Europe 2020
Zaymran Ansar
Cannot change hotmail Pasword behind mikrotik
Fri May 30, 2008 9:24 am
Cannot change hotmail Pasword behind mikrotik, can any one help , i m using hotspot and mangle options too.
savagedavid
Trainer
Trainer
Re: Cannot change hotmail Pasword behind mikrotik
Fri May 30, 2008 12:16 pm
Need more detail. Chances are if you are behind a DSL router that you need to add a mangle to change the MSS value - this has been fairly well documented elsewhere.
savagedavid
MTCE+T (MikroTik Certified Everything + Trainer)
MikroTik support and training in South Africa
http://www.mikrotiksa.com
david [at] mikrotiksa dot com
Zaymran Ansar
Fri May 30, 2008 2:29 pm
thanks for reply, Acctually , i m not using dsl, its an international TWA banwidth for internet with a fiber optic link directely connected to my mikrotik Network Adapter, Even if i stop using mangle rules , it wont solve that problem, i think , it is some kind of double https page problem, i tried disabling all static firewall filters but nothing happen, may be its a hotspot problem.
one more thing,
i have two network running on two different location, with same mikrotik settings and i dont have any problem on the other mikrotik system ,
can u tell me if it is some kind of hardware compatability problem, with machine or network adapter may be.
waiting
fatonk
Fri May 30, 2008 3:12 pm
Try to decrease the MSS
regards
faton
Zaymran Ansar
Fri May 30, 2008 3:58 pm
regards
faton
same problem after decreasing mss to 1460 and 1420
fatonk
Fri May 30, 2008 5:28 pm
is your upload traffic OK,
Zaymran Ansar
Sat May 31, 2008 4:28 am
yes , upload traffic is ok, more then 200 user r connected to mikrotik without having any kind of problem except , this hotmail options page.
Normis , can u help please?
thanks.
Zaymran Ansar
Re: Cannot change hotmail Pasword behind mikrotik(still waiting)
Sun Jun 01, 2008 10:38 am
thanks.
still waiting for help
Users browsing this forum: MSN [Bot], nowinskit and 123 guests
