BuccaNET
Lost graphs - issue
Sat Jun 21, 2008 6:39 pm
Recently, we lost power. I was able to do a system shutdown before the power went out. However, the power came back before the UPS died. So I unplugged the RB1000 and plugged it back in.
Later I accessed the graphs, and they were all missing. I noticed that the time had reset, which is an issue with the RB1000 when it loses power. I have an ntp server set up but the time didn't get set and now all of the graphs are gone.
Thanks,
Cory
mac86
Re: Lost graphs - issue
Wed Jun 25, 2008 3:03 am
Thanks,
Cory
I've same issue with 3.10 and x86 version.
somebody ?
regards
GREG3f
Wed Jul 08, 2009 1:21 am
Any solution to this issue? Running 3.25 and if router get's rebooted, graph history is lost? Using a PC graph history is saved even after shutdown. We have a 2 GB CF in the RB1000.
Really need to keep history. Any suggestions.
NAB
Trainer
Trainer
Wed Jul 08, 2009 6:33 pm
Depending on what you're graphing, it may be better to consider an independent solution - have you seen the http://forum.mikrotik.com/viewtopic.php?f=2&t=28947 thread?
Nicholas Barnes BSc(hons)
Certified Mikrotik Consultant
Certified Mikrotik Trainer
Vitell - Asterisk, Linux and network consultants
Unofficial IRC channel: #routerboard on irc.z.je
GREG3f
Tue Jul 21, 2009 2:56 am
All I want/need is for the RB to keep the history like our PC ROS does. We can reboot the PC any time and it keeps the graph data. I have also confirmed that an RB600 also keeps it's data... just the 1000 does not?
ronniee
Wed Jun 23, 2010 5:43 pm
I run a RB1000 with a CF.
At graphing menu I have selected "Store on disk", but after a restart I lost the graphs. :(
How can I set the graphs to be stored at CompactFlash??
thanks
Users browsing this forum: MSN [Bot] and 62 guests
