MUM Europe 2020
kostil
ospf distribut list
Fri Jun 27, 2008 2:18 pm
i cut some not usefull routes from incoming and outgoing redistribute like this on my cisco router
i leave only needed routes in this example
router ospf 999
router-id X.X.X.X
log-adjacency-changes
network X.X.X.X 0.0.0.7 area 0
distribute-list 30 out
distribute-list 30 in
access-list 30 permit Y.Y.Y.0 0.0.0.63
access-list 30 permit Z.Z.Z.0 0.0.0.127
access-list 30 permit A.A.A.128 0.0.0.127
access-list 30 permit S.S.S.0 0.0.0.255
how can i make this on mikrotik?
Chupaka
Re: ospf distribut list
Fri Jun 27, 2008 3:36 pm
Routing - Filters?
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
kostil
Fri Jun 27, 2008 3:59 pm
could you give me more concrete example?
mrz
Sat Jun 28, 2008 1:05 pm
To filter ospf routes use ospf-in and ospf-out chains.
Example drop all incoming routes except default route:
/routing filter
add chain=ospf-in prefix=0.0.0.0/0 invert-match=yes action=discard
Routing filter manual:
http://www.mikrotik.com/testdocs/ros/2. ... filter.php
Chupaka
Sat Jun 28, 2008 1:08 pm
hm... why 'invert-match=yes'?
mrz
Sat Jun 28, 2008 1:19 pm
kostil
Sat Jun 28, 2008 1:40 pm
and how i can to accept two or three net?
/routing filter
add chain=ospf-in prefix=A.A.A.A/24 invert-match=yes action=discard
add chain=ospf-in prefix=B.B.B.B/24 invert-match=yes action=discard
in this case net A.A.A.A/24 accepted but B.B.B.B/24 not :(
mrz
Sat Jun 28, 2008 1:53 pm
/routing filter
add chain=ospf-in prefix=A.A.A.A/24 invert-match=no action=accept
add chain=ospf-in prefix=B.B.B.B/24 invert-match=no action=accept
add chain=ospf-in action=drop
Chupaka
Sat Jun 28, 2008 3:59 pm
why is there another filtering in RIP? what is difference?
che
Sat Jun 28, 2008 6:46 pm
I have one question regarding this.
Is there a way of blocking large segment of distributed routes instead of filthering exact small segments? For example, I have /30 networks that are distributed and are part of /24 segment, and when I try to use more globar rule it does nothing. I have to have exact rule for every distributed network in route list, no matter the size?
Chupaka
Sat Jun 28, 2008 7:01 pm
use 'prefix length', set it to '24-32', for example
che
Sun Jun 29, 2008 1:06 am
Thank you. :)
Users browsing this forum: MSN [Bot] and 108 guests
